2020 Styrian Grand Prix - Spielberg, 10-12 July
Zynerji
112
Re: 2020 Styrian Grand Prix - Spielberg, 10-12 July
RZS10 wrote:
13 Jul 2020, 01:01
I hate the liveries of Williams/Alpha Tauri and Alfa Romeo/Haas ... from certain cameras it's hard to tell them apart, not that it matters but it's still annoying.
I have definitely felt this as well...
Wynters
Wynters
komninosm wrote:
13 Jul 2020, 01:00
They don't fill up the cars because they cannot use the extra fuel, because the tires overheat. It's a bit of a self-fulfilling prophecy.
Also filling up the whole fuel load would make the car heavy and slow (and is bad on tires too). While half-filling up during pit stops would not have that problem. You would use your whole fuel allotment too.
So Refueling is far from the worst thing F1 could reintroduce.
The drivers who raced with the concrete tyres openly talk about their fuel saving. It's quicker to carry less weight and fuel save than it is to carry more fuel. The only way around it is to mandate a high minimum amount of fuel carried.
komninosm wrote:
13 Jul 2020, 01:00
"We don't need more pit stops" is just your opinion. Some people do enjoy the strategy part of F1 too, not just the racing on track. Besides, this will also give you more on track action/battles as the cars will be on different strategies and have to overtake more (and it will be easier too). Less processions.
Either the cars all use the optimal strategy, or they finish the race more slowly than their competitors. The only reason you see variations at the moment is people gambling. That's not strategy, that's luck.
The sad fact of the matter now is that teams are much bigger, there's far more data, far more processing power and a far greater understanding of the variables. All the teams arrive at the same conclusion for strategy pretty much every single time. Whether there is one pitstop or ten, they'll all stop at broadly the same time for the same number of times. Adding pitstops in the current meta simply adds more chances for pit crews to mess up and decreases the amount of time cars spend on track racing.
2007 - Beats 2005 & 2006 WDC Alonso. 1-0
2008-09 - Beats Kovalainen. 2-0
2010-12 - Beats 2009 WDC Button. 2-1
2013-16 - Beats 2016 WDC Rosberg. 3-1
2017-21 - Beats Bottas. 5-0
2022-24 - Loses to Russell. 1-2 (but outscores him)
2025-?? - Leclerc. TBC
Just the car???
Schuttelberg
Verstappen looks a little fed up.
JordanMugen
86
13 Jul 2020, 00:27
Stop a second time and you are 25 seconds behind where you were with the trye advantage not enough to make it up.
To reduce that punishment.
My solution was to bring back refuelling
Why not just make a rule that you have to do two pitstops and/or use three different compounds of tyre in a dry Grand Prix? Wouldn't that achieve the same result of spicing up strategies? :?:
Schuttelberg wrote:
13 Jul 2020, 02:28
Should have signed for Mercedes. :cry:
holeindalip
holeindalip
Didn’t Red Bull protest Mercedes and racing points brake ducts in Australia already because the opening was in the wrong place on the rears? If true then the brake ducts have been modified from stock spec and won’t match, or did that happen last year? I’ve slept since then.....
foxmulder_ms
foxmulder_ms
holeindalip wrote:
13 Jul 2020, 03:13
Yes, 2020, w11. They were taller than they supposed to be.
holeindalip
holeindalip
foxmulder_ms wrote:
13 Jul 2020, 03:17
holeindalip wrote:
13 Jul 2020, 03:13
I remember racing point had to change theirs also, am I wrong there????
foxmulder_ms
foxmulder_ms
Schuttelberg wrote:
13 Jul 2020, 02:28
Well, he probably realizes first 3 races were the best chances RebBull has and so far doesn't look good at all. I think Mercedes can win all races bar engine failures... What type of circuit Mugello?
foxmulder_ms
foxmulder_ms
holeindalip wrote:
13 Jul 2020, 03:20
foxmulder_ms wrote:
13 Jul 2020, 03:17
holeindalip wrote:
13 Jul 2020, 03:13
I dont remember what RP did. w11 has definitely changed the design though.
dans79
267
I just watched the sit down post race interview, and Max sounds like he's ready to give up on the rest of the season.
202 105 104 9 9 7
JonoNic
foxmulder_ms wrote:
Schuttelberg wrote:
13 Jul 2020, 02:28
Mostly fast chicanes and double apex corners.
Sent from my SM-A520F using Tapatalk
zeph
zeph
Funny, last weekend someone said that Hamilton wouldn’t win the crown this year because he was too preoccupied with #BLM. Love to hear if that dude still holds that opinion.
Anyway, Sainz really unlucky today with that pit stop, and Norris once again gobbled up all of McLaren’s luck, great result for him. I felt Stroll pushing Ricciardo off the track was borderline penalty, but hey, at least the kid’s racing! Still, Hamilton got a penalty for much less than that last weekend.
Ferrari, well, you know....
Phlumbert
Phlumbert
dans79 wrote:
13 Jul 2020, 04:22
It seems like the W11 has a significant tire life advantage over the RB-16 right now. Some of that might be down to the cooler temps and setup but I think the fact the Lewis was able to punch in the fastest lap (at the time) on 35 lap old mediums was a good sign of Merc's advantage.
Fulcrum
Fulcrum
13 Jul 2020, 00:34
@ the Renault protest. Perhaps Renault is seeking clarification to know if they can copy Mercedes Brake ducts too!
There is an entire car's worth of parts requiring clarification.
Perhaps the brake ducts are merely the first in a long line of protests designed to do nothing other than disrupt Racing Point?
Lando Norris's onboard for the final two laps overtaking the RPs. Good work by the engineer helping him with the car management etc. Excellent example of the team work required to race a modern F1 car.
