Mercedes W11
ispano6
167
Re: Mercedes W11
The Truth about DAS, from Auto Sport Magazine. I've added the yellow translations
zibby43
zibby43
Re: Mercedes W11
OO7 wrote:
20 Sep 2020, 08:42
zibby43 wrote:
19 Sep 2020, 23:52
Mechanics POV: Mercedes F1 Mechanics Prepare W11 for Qualifying =D>
Incredible opportunity to see some critical areas of the car up close.
Yeah that was an awesome video zibby. We got a look at the sidepod rad (partially covered) which may have a slight curvature to it, as well as the uninstalled floor (around the bib/tea-tray) and a clean shot of the steering wheel during clutch bite point check. That car is something else!
I was also surprise at the number of exposed boxes there are in the cockpit (when Lewis was being strapped in).
That struck me as well. Would love it if all the teams did this.
Mattchu
65
Re: Mercedes W11
32Smooth wrote:
20 Sep 2020, 09:56
zibby43 wrote:
19 Sep 2020, 23:52
btw: what are brake bypass ducts and why are they used in fp3?
They use them all the time, it`s just an air duct that goes over the brake disc into the cake tin which needs checking to make sure it`s clear of debris. Some air is vented onto the disc to help cool it and also blow the warmer air onto the rim to help with tyre temperature.
Later on they show it back in place, then later with the cake tin back on covering it. These ducts can only protrude so much above the wheel center line and Merc and Racing Point got pulled for it earlier in the season for having an intake duct to high!
Re: Mercedes W11
The bypass duct does as its name implies. It ducts air around the brake and directly outwards through the wheel. It replicates the old blown axle.
cramr
cramr
Re: Mercedes W11
Just_a_fan wrote:
21 Sep 2020, 20:35
This was already used even with the blown axle. Teams want as much outwash as possible from the rim
Re: Mercedes W11
Hmmm seems like the bypass duct introduces cooler air into the wheel outwash. The brake tins probably introduce hot air. Maybe the Mercedes needs temp difference for their brake ducts to work. Probably why they're not as dominant when the ambient temp is high.
HungarianRacer
HungarianRacer
37
Re: Mercedes W11
Would someone post pictures of the two bodywork configurations Valtteri and Lewis trialed in FP1 please?
Which one do you guys think is the higher cooling spec anyway? BOT's car had the bloated bodywork around and behind the exhaust manifold area, but with clearly smaller and narrower (making it technically a more "pinched in" bodywork) rear outlets compared to HAM's config, who had what has been the "relatively high" cooling setup ever since they introduced their 2019 Germany upgrade package...
zibby43
zibby43
Re: Mercedes W11
HungarianRacer wrote:
25 Sep 2020, 11:33
I'll see what I can find. In the meantime, here's the wheel:
One thing I have picked up on in looking for the requested photos, is that both cars appeared to run the “old” FW spec that had the split tip on the flap just below the uppermost flap.
zibby43
zibby43
Re: Mercedes W11
One of the possible cooling specifications:
The return of the split-flap FW:
Barge boards shot via AMuS
Re: Mercedes W11
Here are two cooling configs
via @Gianludale27
OO7
OO7
171
Re: Mercedes W11
I think both cars were running the Bottas solution during FP3, definitely Hamilton but I'm not 100% sure on Bottas' car.
F1Krof
96
Re: Mercedes W11
Is Mercedes' front-wing upper flap split or is it just the reflection?
Source: @MercedesAMGF1, via Twitter.
Wroom wroom
zibby43
zibby43
Re: Mercedes W11
F1Krof wrote:
07 Oct 2020, 18:39
https://pbs.twimg.com/media/EjvU3UmXkAI ... =4096x4096
Reflection. Only the flap under the uppermost flap has the split-tip.
Re: Mercedes W11
Art.
DarthPlagueisTheVise
42
Re: Mercedes W11
Merc have got their mugello fw flap again
Technical Noob
