Mercedes W11
SiLo
126
Re: Mercedes W11
MtthsMlw wrote:
Sat Sep 26, 2020 10:20 am
Here are two cooling configs
https://pbs.twimg.com/media/Ei1DcNcXgAE ... name=large
via @Gianludale27
This looks like its dependent on how large the rear wing is. Trying to keep the same distance from the top of the cooling outlet to the bottom side of the rear wing.
Felipe Baby!
HungarianRacer
HungarianRacer
36
Re: Mercedes W11
SiLo wrote:
Fri Oct 09, 2020 12:50 pm
via @Gianludale27
Well, in Hungary they ran with the high & narrow outlets combined with their full-fat rear wings, but with extremely narrow bodywork around and behind the exhaust manifold area.... Seems to be a theme with Mercedes' cars isn't it, they start the season with borderline cooling, then they learn how to loosen up the rear packaging (for improved reliability, presumably) without sacrificing much - or any - aero performance.... With maybe the exception of the W06 (2015), I believe you'll find this to be 100% true.
zibby43
zibby43
612
Re: Mercedes W11
DarthPlagueisTheVise wrote:
Fri Oct 09, 2020 11:10 am
Merc have got their mugello fw flap again
Nice spot.
jh199
32
Re: Mercedes W11
Would someone mind explaining to me how DAS is used to heat the tires? The way I understand it is that using DAS reduces the front toe out. Toe out increases front tire scrubbing so using DAS would decrease tire scrub. Tire scrub can be used to heat the tires. So how does reducing tire scrub result in increasing front temperature?
Sorry if this is a silly question. I just genuinely don't understand how they use it to heat the fronts.
zibby43
zibby43
612
Re: Mercedes W11
jh199 wrote:
Mon Oct 12, 2020 12:22 am
Great question. Basically, the tires will heat up more evenly across the width of the tread when they're running fully upright, as opposed to the toe-out configuration.
In other words, a critical element of heating the tires is not just "peak" heating, but *uniform* heating across the width of the tread for maximum grip/consistency.
Hope I explained that clearly.
42
Re: Mercedes W11
Does anyone have a photo of the cooling option used on the w11s this weekend? It was looking really tight
Technical Noob
jh199
32
Re: Mercedes W11
zibby43 wrote:
Mon Oct 12, 2020 5:33 am
Ohh ok thanks Zibby. I totally get it now
Big Tea
Re: Mercedes W11
If you think of it as a switch, it can be 'normally' on or 'normally ' off
jh199
32
Re: Mercedes W11
Big Tea wrote:
Mon Oct 12, 2020 5:32 pm
Could you elaborate a bit on this point? Are you saying "normally on" is when DAS is activated and thus, toe out is reduced? In this case there is more even surface heating across the front tires contact patch and therefore the driver has more control over front tire heating. And then "normally off" is when the front tires are in their toe out settings?
Big Tea
Re: Mercedes W11
jh199 wrote:
Mon Oct 12, 2020 5:47 pm
It depends on the setting and if normal is 'in' or 'out' with the steering wheel.
For simplicity, lets say 'normal' is parallel. (it probably will not be but a few deg off)
Call wheel toward the driver as off and can be either parallel or toe in/out by (say) 10deg
The options are to reduce toe for less scrub and more speed when wanted, or (if that is normal) to add toe and increase friction, reduce performance when not.
So 'on' can be adding toe, or reducing toe, depending on which is 'normal'Does that make sense? #-o
PS, I hasten to add this is just MY theory, not from Merc
Mchamilton
Mchamilton
Re: Mercedes W11
You have it the wrong way round. DAS increases the toe on the front wheels, increasing scrub, and therefore tyre temp as you mentioned.
jh199
32
Re: Mercedes W11
Yea so I understand your point Big Tea. I was just wondering why it would be used for tire heating if using DAS (pulling the wheel toward you) decreased toe out. Zibby explained that it's to prevent peak heating and obtain more uniform heating instead.
You and Mchamilton both touched on something and I believe you two may be mistaken here. You said "add toe and increase friction, reduce performance" and Mchamilton stated, "DAS increases the toe on the front wheels, increasing scrub". Yea, it does increase toe but only with reference to the 0 toe state which is not its normal state.
When the driver pulls the wheel, the toe out reduces from 3 ish degrees out to 0 ish degrees out. If you go back and watch the onboard videos, you see that the drivers have the steering wheel pushed in (i.e. toe-out) for all racing laps at speed. Therefore this should be considered the normal condition, so the normal state is 3 ish degrees out. This makes sense as well considering historically race cars are set up with a bit of toe-out. Pulling the steering wheel toward the driver (i.e. activating DAS) reduces the front toe to 0 ish degrees.
Now, I do have one new question. Watching the onboard you can see that Lewis only weaves when the tires are in their normal (toe-out) state. This makes sense to me because the angle of toe-out plus the increased steering angle from weaving will result in more front tire scrub and thus more front tire heating. He only sets the toe out to 0 degrees when he is traveling in a straight line. So calling back to Zibby43, Lewis doesn't weave or aggressively brake and accelerate when the tires are set at 0 degrees toe out so he must not be heating the tires when the tires are set to 0 degrees toe-out. So then the peak vs uniform heating argument doesnt really apply, right?
I don't mean to beat a dead horse here (DAS has like, 20 pages worth of discussion already) but I don't think my questions have been answered on this forum yet.
Big Tea
Re: Mercedes W11
jh199 wrote:
Mon Oct 12, 2020 7:04 pm
Does toe out not work the inner edge and toe in work the outer edge?
dans79
262
Re: Mercedes W11
I think you might be looking at it a little to simply. The underlying tech allows the drivers to adjust toe on the fly. I'd be willing to bet that range of adjustment and the stop locations are all adjustable. By that I mean On one track total range of movement might be 2 degrees and on another it might be 6. On one track the stops might be at +4 and 0 degrees, at another it might be +2 and -2. Several factors are going to go into determining how DAS is configured, and it's going to be tire allocation, track, and weather dependent. Probability of a safety car is probably considered as well. You also need to keep the Ackerman in mind as well.
197 104 103 7
jh199
32
Re: Mercedes W11
dans79 wrote:
Mon Oct 12, 2020 9:04 pm
Perhaps I am underthinking it. If pulling the wheel toward you results in a negative toe angle then I totally understand the system. I was assuming the toe angle just went to 0 degrees. In this case, the inner and outer edge can be heated separately as Big Tea has mentioned.
Alright, thanks all. I'll drop this topic now
