Mercedes W11
lio007
327
Re: Mercedes W11
The floor:
Edit: compared to last years (I think)
source: viewtopic.php?p=942169#p942169
zibby43
zibby43
Re: Mercedes W11
Re: Mercedes W11
lio007 wrote:
03 Dec 2020, 20:19
The floor:
https://cdn-1.motorsport.com/images/mgl ... tail-1.jpg
https://i.redd.it/m817scvambaz.png
2017
DarthPlagueisTheVise
42
Re: Mercedes W11
Mercedes has a new steering wheel the shape is different at the top
Technical Noob
Re: Mercedes W11
DarthPlagueisTheVise wrote:
04 Dec 2020, 15:34
Possibly they went with an earlier design that George found more comfortable or on which he prefered the switch layout.
42
Re: Mercedes W11
Just_a_fan wrote:
04 Dec 2020, 15:40
04 Dec 2020, 15:34
Valtteri was the one using it though
Technical Noob
Re: Mercedes W11
04 Dec 2020, 15:41
Just_a_fan wrote:
04 Dec 2020, 15:40
04 Dec 2020, 15:34
Ah, I thought you were commenting on the photo of Russell. Sorry.
Sieper
73
Re: Mercedes W11
04 Dec 2020, 15:41
Just_a_fan wrote:
04 Dec 2020, 15:40
04 Dec 2020, 15:34
George was running DAS, Valterri was not (today).
42
Re: Mercedes W11
Technical Noob
nico5
25
Re: Mercedes W11
I'm too lazy to upload pictures, but just wanted to point out that today on VB's pole lap, on the middle section of his dash, underneath the gear and the Strat setting (which is purple for qualifying, Strat 2), it was showing him the current state state of ERS deployment. I think that box used to be allocated for the actual HPP mode (it's the one that would change when they were pressing the OT button in race trim or when they were using Strat 2 in Q2 with medium tires but no party mode yet).
Anyways, you can see the exact moment when it switches from presumably free load (purple) to H-to-K (blue) to no-deployment (white) during each phase of the acceleration.
https://www.youtube.com/watch?v=nKJ8e15a2yw&t=35s
i70q7m7ghw
i70q7m7ghw
49
Re: Mercedes W11
Interesting to see VB has switched to a single clutch paddle LH has been using all season. He had been using the double paddle system until recently.
GioKer32
GioKer32
Re: Mercedes W11
I've just read an article from "The Race" regarding Russel's struggles to keep pace with Valtteri at turn one, and I found this part really interesting: "It did it (creating more downforce volume between the tires and the diffuser) by mounting the lower leg of the rear wishbone into the crash structure, rather than the gearbox ahead of it. This allowed the whole suspension to be swept back. It was a massive engineering challenge. What that gave was a car with rear tires that would no longer be overwhelmed by a super-positive front end set-up. The car could be hustled into slow corners, late and positive on turn-in, without the rear becoming upset."
Apart from the fact that it's not something newly discovered, with the expression "super positive front end set-up", what do they precisely mean?
ScrewCaptain27
577
Re: Mercedes W11
GioKer32 wrote:
09 Dec 2020, 09:41
Lots of front-end mechanical grip, lots of steering.
- Serj Tankian
GioKer32
GioKer32
Re: Mercedes W11
ScrewCaptain27 wrote:
09 Dec 2020, 09:42
This also explains why last year's Merc was so good at low-speed corners but a bit "lazy" at the exit of them, doesn't it? :?:
Although, at present, it seems to have been brilliantly solved.
Mylesk
Mylesk
Re: Mercedes W11
04 Dec 2020, 15:34
Any word of Mercedes trialing this wheel again today?
