Pulse-jet MGU-H
Zynerji
111
Pulse-jet MGU-H
Could an F1 type MGUH turbo be used like this to power hub-mounted K units?
That sound would be epic with 20 cars on the starting grid...
Zynerji
111
Re: Pulse-jet MGU-H
180 views with no opinions...
Maybe I should have said "It's the car, and not Hamilton", and I would have gotten some play.🙄
Xwang
29
Re: Pulse-jet MGU-H
If and when F1 rules will permit to use turboprop engines maybe.
FW17
165
Re: Pulse-jet MGU-H
Didnt Jaguar and Williams try something like that and fell on their face with that CSX
Stu
Re: Pulse-jet MGU-H
Zynerji wrote:
12 Feb 2021, 19:27
It would be excellent! And as you are using the ‘engine’ to purely generate electricity it could be run at its most efficient rpm.
Big Tea
Re: Pulse-jet MGU-H
Rover/BTM entered a turbine in Le Mans (not pulse jet, but I thought I would post it anyway)
617
Re: Pulse-jet MGU-H
Stu wrote:
14 Feb 2021, 21:49
at the trivial power of F1 a free-piston engine/linear generator would be (much) more efficient
if kept generator-only it wouldn't need to limit the cycle rate so wouldn't sound like a big-block V8
Greg Locock
233
Re: Pulse-jet MGU-H
Strictly speaking the photo in the first post isn't a pulse jet either.
Zynerji
111
Re: Pulse-jet MGU-H
Whatevs.
Running 2 of these in a car with twin MGUH could be bad a55.
Holm86
243
Re: Pulse-jet MGU-H
Zynerji wrote:
22 Feb 2021, 02:48
Whatevs.
I had speculated earlier that if they didn't have the 100kg fuel limit, (still keep flow limit of 100kg/h) they might run a little extra fuel, to dump into the exhaust when off throttle. Using an antilag system to keep the MGU-H spinning.
Running mini-jet engines to drive the MGU-H would not be a great idea I think. I don't think jet engines sound particularly good, its just a bunch of very loud white noise.
Zynerji
111
Re: Pulse-jet MGU-H
Holm86 wrote:
22 Feb 2021, 10:17
Zynerji wrote:
22 Feb 2021, 02:48
Whatevs.
...but electric torque and THRUST! 🤣🤣
Big Tea
Re: Pulse-jet MGU-H
Dont know if this fits in the engine or aero section,but it is propulsion, so i put it here
Dont know if it could be adapted to assist an F1 car?
