Nissan 50% TE engine concept
Brake Horse Power
Where Volvo announced to completely ban ICE by 2030, Nissan sees opportunities for high efficient combustion engines. They currently have a 46% TE engine, and have a small roadmap to achieve 50%. They focussed on airflow in the cylinder and lean burn. I didn’t notice any pre-combustion chambers in the presentation.
NL_Fer
82
Re: Nissan 50% TE engine concept
50% TE but how much is lost in that serial hybrid driveline?
manzieza
Contact:
It Great !
lucafo
Please, share the link
gruntguru
563
NL_Fer wrote:
14 Jul 2021, 07:57
The loss due to the serial drivetrain is more than offset by the gain from operating the engine constantly at its peak efficiency point. They are also able to increase peak efficiency at the design stage since efficiency at other operating points becomes less important.
621
NL_Fer wrote:
14 Jul 2021, 07:57
no more than that lost in any other driveline that has a continuous relationship between motor and load ?
vorticism
323
just combine the electrical machine efficiency losses. Maybe 2% loss for generator, same for motor. 96% efficient driveline. Less than a driveshaft and gear, but maybe on par with other types of CVT. Next question is, would it be better to use batteries, capacitors, or a flywheel for the buffer storage.
It's an appealing concept but requires two equally sized MGUs and their controllers. In a performance application, it will be hard to beat a gearbox, for weight.
𓄀
Zynerji
110
vorticism wrote:
15 Apr 2022, 18:11
I like twin, counter rotating flywheels under the rear floor...😏 To prevent porpoising! 😂
vorticism
323
Zynerji wrote:
15 Apr 2022, 20:32
vorticism wrote:
15 Apr 2022, 18:11
To think Audi and Porsche were using them not long ago. No longer though.
The MGUH can rotate at 100k+ rpm, it should be ideal for flywheel storage. Edit: depends on inertial forces, although similar bearing and motor tech could be transferred.
𓄀
Zynerji
110
vorticism wrote:
15 Apr 2022, 23:18
Zynerji wrote:
15 Apr 2022, 20:32
vorticism wrote:
15 Apr 2022, 18:11
MLC flywheels like the Williams original has nothing to do with current MGUH tech. The RPMs being similar is about the only congruence.
vorticism
323
True. The Audi LMP and Porsche GT examples were electrical though. Now that you mention it perhaps Williams flybrid (?) tech could be combined with a turbocharger to make an analog MGUH.
𓄀
Zynerji
110
vorticism wrote:
15 Apr 2022, 23:28
I think the vacuum chamber is tough to integrate into a turbo tho.
vorticism
323
Zynerji wrote:
15 Apr 2022, 23:44
Def keep the compressor out of the vacuum chamber.
𓄀
NL_Fer
82
Maybe driveline losses are not such a problem on busy or hilly Asian traffic, compared to an automatic transmission
