Ferrari SF21
Re: Ferrari SF21
that's some skinny, tight area at the gearbox section :shock:
and that nose is interesting. That's quite the refined car imho, didn't expect so 'much' change
HungarianRacer
HungarianRacer
35
Re: Ferrari SF21
JPower wrote:
10 Mar 2021, 15:26
Anyway, I found the launch video to be actually informative for once.
Compared to the other cars it seems like Ferrari has made the most visible changes for 2021. I guess we’ll find out if they’re good ones soon.
Even more changes than Aston you reckon?... I mean, they have a complete new rear end inherited from Mercedes, and completely different sidepods/monocouqe middle section aswell....
v3rify
v3rify
Re: Ferrari SF21
brake ducts look significantly bigger or maybe its just the change in shape? Image
cplchanb
cplchanb
Re: Ferrari SF21
How can they not use any tokens for the nose??? It's been modified quite heavily similar to alfa Romeo.
Re: Ferrari SF21
that's a really good looking car from this angle. interesting angle aswell!
reminds me of the 2007/2008 cars with the 'excessive' fins everywhere.
Cuky
65
Re: Ferrari SF21
cplchanb wrote:
10 Mar 2021, 15:55
Apparently they didn't change the crash structure inside the nose (that is the part that is homologated and tokens must be used to change it) but just changed the bits on the outside.
aerofoilf1
aerofoilf1
247
Re: Ferrari SF21
Nose compare
Re: Ferrari SF21
Via @SomersF1
Via @andihaupt1
JPower
JPower
43
Re: Ferrari SF21
HungarianRacer wrote:
10 Mar 2021, 15:52
JPower wrote:
10 Mar 2021, 15:26
Even more changes than Aston you reckon?... I mean, they have a complere new rear end inherited from Mercedes, and completely different sidepods/monocouqe middle section aswell....
Visibly I think so. They’ve seemed to have touched almost every section on the SF21’s bodywork and it also is sporting a new rear suspension. The Aston at least kept the same nose design.
Either way, I’m pretty impressed so far.
mantaque
mantaque
Re: Ferrari SF21
Interesting detail: looks like exhaust wastegate pipe has a change in diameter:
Mr.G
34
Re: Ferrari SF21
mantaque wrote:
10 Mar 2021, 16:05
https://i.imgur.com/l0VEThU.png
The end is defined by rules, so they must to comply...
Re: Ferrari SF21
mantaque
mantaque
Re: Ferrari SF21
Mr.G wrote:
10 Mar 2021, 16:07
mantaque wrote:
10 Mar 2021, 16:05
Like with everything, but I just wonder what advantage you gain with this design.
Mr.G
34
Re: Ferrari SF21
mantaque wrote:
10 Mar 2021, 16:11
Mr.G wrote:
10 Mar 2021, 16:07
mantaque wrote:
10 Mar 2021, 16:05
They can have thinner pipe = less weight, then the rules define it must be wider for the last few cm, so they changed the diameter back...
Re: Ferrari SF21
Via @NicolasF1i
