McLaren MCL35M
Re: McLaren MCL35M
f1rules
f1rules
623
Re: McLaren MCL35M
the EDGE
the EDGE
68
Re: McLaren MCL35M
It was mentioned on Sky coverage that Siedl said McLaren were back to back testing different floors yesterday
Are then any pictures showing the differences?
Re: McLaren MCL35M
Craig Scarborough:
Note how much downwash is occurring, even high from behind the halo, the streamlines go under the coke bottle tail.
The also not the outwash effect, streamlines right up agajnstctgs sidepod, swerve outwards across the front of the rear tyre
chrisgr
chrisgr
Re: McLaren MCL35M
Is Mclaren the only team that uses flow-viz? at least so often...
Mansell89
Mansell89
Re: McLaren MCL35M
Karun been reading your posts on the diffuser guys :D
Re: McLaren MCL35M
chrisgr wrote:
13 Mar 2021, 12:46
Also just saw flow-viz being used under the nose... Just in front of the floor...
bosyber
bosyber
45
Re: McLaren MCL35M
chrisgr wrote:
13 Mar 2021, 12:46
No, though they do seem to use quite a bit (maybe more than others), we also saw the stranded Merc of Hamilton having the mirror's covered, and next to the front of the sidepod at the floor, but they use stuff that mostly shows up under ultraviolet only. Think Red Bull do the same, keeping it more secretive.
f1rules
f1rules
623
Re: McLaren MCL35M
yeah it only took the sky team 1.5 day to recognize the diffuser trick, though already early yesterday it was uncovered by a twitter user, would be nice if they seeked some additional info, instead of their constant bla bla bla, sometimes its to easy to be a f1 journalist
JordanMugen
86
Re: McLaren MCL35M
frosty125 wrote:
12 Mar 2021, 13:05
I wonder if many other teams will have found this?
I'm not sure I see how that is beneficial though. It fences that whole central section (of expansion) off from the rest of it, which doesn't seem that desirable. :?:
MCL35 version:
Edit - Oh I see, the fence still firstly tapers inwards a bit on the MCL35M, which could work. Plus the below the step section of the floor gets it's own little "mini diffuser", very cute. :D
Re: McLaren MCL35M
Peter Prod seems to be in his element again...
Big Tea
Re: McLaren MCL35M
chrisgr wrote:
13 Mar 2021, 12:46
Do some teams not use UV, so we do not see it?
Ground Effect
Ground Effect
Re: McLaren MCL35M
mclaren111 wrote:
13 Mar 2021, 13:31
Exactly what I was just thinking! Probably this is more like the team he thought he was joining. I hope this innovation carries on to the 2022 car, big opportunity to close in on the top 2 (3?)
f1rules
f1rules
623
Re: McLaren MCL35M
aerofoilf1
aerofoilf1
247
Re: McLaren MCL35M
Explanation of how/why they have done this diffuser design
