Mercedes W12
El Scorchio
Re: Mercedes W12
amppatel wrote:
23 Mar 2021, 13:36
This seems to be the first (and only) picture of the rear from the testing day - from their FB page. From what you can see, it seems the same as before:
https://scontent.fltn3-1.fna.fbcdn.net/ ... e=608036AA
If that's the rear of the cars, then it's certainly radical and they were right about it being obvious what the changes were....
mkay
mkay
16
Re: Mercedes W12
El Scorchio wrote:
23 Mar 2021, 14:29
amppatel wrote:
23 Mar 2021, 13:36
Can you please expand on that? I'm not as technically gifted and do not have CFD eyes, so to me this looks exactly like what they tested 10 days ago.
El Scorchio
Re: Mercedes W12
mkay wrote:
23 Mar 2021, 15:07
El Scorchio wrote:
23 Mar 2021, 14:29
amppatel wrote:
23 Mar 2021, 13:36
The picture is of the cars front on. So it's not the rear. It was a joke :)
And there's no way they are posting pictures of anything new or secret on their facebook page.
mkay
mkay
16
Re: Mercedes W12
El Scorchio wrote:
23 Mar 2021, 15:09
mkay wrote:
23 Mar 2021, 15:07
El Scorchio wrote:
23 Mar 2021, 14:29
=D> to you and #-o to me...
On another note, Somers came out with an interesting piece on the W12 earlier today. Seems to think Merc hasn't shown everything yet.
https://www.motorsport.com/f1/news/is-m ... n/5863056/
El Scorchio
Re: Mercedes W12
mkay wrote:
23 Mar 2021, 15:11
El Scorchio wrote:
23 Mar 2021, 15:09
mkay wrote:
23 Mar 2021, 15:07
Haha no worries! It wasn't the greatest joke ever told, by any stretch :)
Interesting article, that. Good summary of the unknown surrounding the car.
aral
aral
26
Re: Mercedes W12
Another reminder....CAR ONLY please
SmallSoldier
SmallSoldier
488
Re: Mercedes W12
It seems they tried a single pilon rear wing during testing and it went unnoticed?
El Scorchio
Re: Mercedes W12
SmallSoldier wrote:
23 Mar 2021, 20:10
https://uploads.tapatalk-cdn.com/202103 ... 54e7d8.jpg
That's interesting. I only saw them running a double- and most other teams were running a single.
But didn't they often run a single last season?
Jolle
Jolle
133
Re: Mercedes W12
El Scorchio wrote:
23 Mar 2021, 20:17
SmallSoldier wrote:
23 Mar 2021, 20:10
Only at circuits with a low load on the rear wing, like Monza
zibby43
zibby43
Re: Mercedes W12
mkay wrote:
23 Mar 2021, 15:11
El Scorchio wrote:
23 Mar 2021, 15:09
mkay wrote:
23 Mar 2021, 15:07
A few of us have been subscribing to that theory for a while now. :)
It just didn’t make sense to me that there weren’t more noticeable changes at the front wing/nose area of the car to correspond with the downstream changes.
As Somers points out, the W12 nose and cape solution on display during the Bahrain test was basically the same concept since ‘17.
Re: Mercedes W12
Jolle wrote:
23 Mar 2021, 21:01
El Scorchio wrote:
23 Mar 2021, 20:17
SmallSoldier wrote:
23 Mar 2021, 20:10
Thinking out loud here, but could a single pylon high downforce rear wing be more susceptible to oscillations and thus make the rear a little unpredictable? A twin pylon set up is obviously going to be much stiffer. I'd be amazed if a team like Mercedes would design a "floppy pylon" but you never know.
zibby43
zibby43
Re: Mercedes W12
The purpose of the rippled floor on the Mercedes:
"The general idea of these upturns on the floor’s edge are to create clockwise vortices of air which will travel down the length of the floor’s outer edge, helping seal it and thereby increasing the air pressure difference between the ambient and the underfloor, which in turn increases the downforce created by that underfloor.
At slow car speeds, as underfloor airflow speed reduces, so it becomes more difficult to seal that floor.
In low-rake cars such as the Mercedes and Aston Martin, that airflow speed will tend to slow more than on a high-rake car (like the Red Bull) which can keep the floor’s flow energised by the greater expansion angle of the floor itself. It would appear that the low-rake cars, under the new regulations which have cut the floor area, need to energise that floor more by way of these sealing vortices.
Another aerodynamic characteristic which can be more problematic for low-rake cars than high is the phenomenon of flutter whereby the airflow beneath the floor can reverberate off obstacles in a cyclic way, creating a disrupting effect unhelpful to the floor’s creation of downforce.
It might be that the revised floor shape for this year has induced this trait more readily and that the vortices from the cut-outs are better able to break that cycle."
https://www.formula1.com/en/latest/arti ... 9ygXo.html
dans79
267
Re: Mercedes W12
Still nothing even close to a shot of the rear of the car! Some decent close up though, if you slow the vide down to 1/4 speed
202 105 104 9 9 7
F1Krof
96
Re: Mercedes W12
dans79 wrote:
24 Mar 2021, 19:44
We'll be disappointing when we see Merc turning on Friday with the same care it had during testing. I'm not believing there will be anything of this sort.
Wroom wroom
dans79
267
Re: Mercedes W12
F1Krof wrote:
24 Mar 2021, 20:23
dans79 wrote:
24 Mar 2021, 19:44
What did they spend their tokens on then? as I've mentioned before literally no one outside the team can figure out what they spent two tokens on.
202 105 104 9 9 7
