This is for the engine block mor than the liner.
Fatigue strength more likely improved.
On the sexy bulge.
Another possibilty is that the plenums are lower wider and biger, with maybe a stronger cross flow... For increased range of the VLIM.
The Aston Martin body works shows the bulge a bit more and the bulge seems to directly a top the engine than i thought before.
hurril
Perhaps the intercooler is in the intake plenum now. That ought to cut down on the piping which seems beneficial.
ryaan2904
36
hurril wrote: ↑
03 Mar 2021, 21:37
If your intercooler goes inside the intake, won't it be more harmful since it'll heat up the intake air to a certain extent
CFD Eyes of Sauron
hurril
ryaan2904 wrote: ↑
04 Mar 2021, 07:50
hurril wrote: ↑
03 Mar 2021, 21:37
Intake plenum. Not the intake.
saviour stivala
51
Yes correct. Intake air 'planum' is compressed air from turbo to cylinders. while intake air is intake air to compressor (before turbo).
Thomas basically confirms that the turbocharger and the parts relating to it have been modified to generate less heat load to the cooling system.
https://www.planetf1.com/news/mercedes- ... novations/
It means probably a more efficient compressor, or a less restrictive intake tract, or better intercooler, or even better turbocharger cooling... All we know is that the heat rejection from turbocharging has been reduced.
This should greatly help the other cooling systems of the engine to run cooler as well.
Views on the new intake plenum
via @SalaStampaF1
Actually it looks tiny and much smaller than 2014-2020 :!:
KAIZEN
74
Plenum chamber
PlatinumZealot wrote: ↑
03 Mar 2021, 21:17
On the sexy bulge.
Yes they are lower and overall width looks bigger
_cerber1
238
From Albert Fabrega
hurril
So instead of forward-facing trumpets, they've gone for a curled-up set? That's what I think judging by the size and shape of the chambers. What do you think?
zibby43
613
Owen.C93
171
hurril wrote: ↑
25 Mar 2021, 00:14
They used to have them set quite far back and routed them forward for the inlets. But I guess the ERS cooler pipework proved to win out and cut down the Z height in the rear area. I would be curious to better understand what's going on under the skin of these plenums.
Longley
It might also be that Mercedes has something up its sleeve, with what is believed to be a super-cooling system within the inlet plenum for short bursts of extra power.
Source: https://the-race.com/formula-1/mark-hug ... ooks-like/
Interesting. About how many hoursepowers are we probably talking here?
