McLaren MCL35M
Re: McLaren MCL35M
Ground Effect wrote:
25 Mar 2021, 13:50
I remember in the AMuS interview with James Key that was posted on here, he was asked why the MCL35M didn’t have the bulge like the Mercedes and Aston Martin. He said they’d gone with a different philosophy, and he then said that’s all he’s going to say on the matter. Made me wonder if he felt McLaren had found something more efficient.
This is the answer why the buldge doesn't show:
The top central cooler is wide, so the plumbing leading to it take up space not allowing them to make the engine cover narrow.
If the top cooler were not there you can see how much narrower the top of the engine cover would be and how the buldge would show.
101FlyingDutchman
101FlyingDutchman
Re: McLaren MCL35M
Clearly it’s been a compromise in a way: probably not being able to seat/engineer the PU down as far (pushing for a lower COG as they would have been able to do if it wasn’t for the limitation of token spend.
On the other hand they then went their own way based on their philosophy of being a higher rake car and keeping some of the architecture similar but benefitting from smaller side pods. A compromise that might actually really work considering this year floor change
Re: McLaren MCL35M
101FlyingDutchman wrote:
25 Mar 2021, 14:19
Tokens do not prevent them from changing and putting the centerline cooling system flat and low backwards like Mercedes, RP and Williams.
There are other reasons (ressources/time shortage, ballast shortage, this system works well, the aim to have the biggest undercut etc)
101FlyingDutchman
101FlyingDutchman
Re: McLaren MCL35M
Blackout wrote:
25 Mar 2021, 14:23
25 Mar 2021, 14:19
Tokens do not prevent them from putting the centerline cooling system flat and low backwards like Mercedes, RP and Williams.
There are other reasons (ressources/time shortage, ballast shortage, this system works well etc)
Quite. But modifications to chassis and gearbox would incur token spend, which normally go hand in hand if you really have free reign (not just on where to put the CCS). And it would probably be impossible to convince the FIA of the need to do that the work
Mansell89
Mansell89
Re: McLaren MCL35M
So any likelihood of photos this morning or will it all be gained from FP1 later this afternoon?
Exciting times, always love a fresh season start!
kfrantzios
kfrantzios
46
Re: McLaren MCL35M
Diffuser detail
By Salvatore Asero
SmallSoldier
SmallSoldier
488
Re: McLaren MCL35M
wowgr8
wowgr8
29
Re: McLaren MCL35M
Really really really impressive how tight the sidepod is right below the inlets when viewed head-on, the tightest of any car and by some distance
Re: McLaren MCL35M
wowgr8 wrote:
26 Mar 2021, 16:21
Pictures ??
Mark4211
92
Re: McLaren MCL35M
New ACS button which was only seen on Bottas's steering wheel and RP/AM's steering wheel is now on the McLaren
Source
Ground Effect
Re: McLaren MCL35M
The front wing on the car is the 2020 spec?
Reason: removed FP timing discussion
f1rules
f1rules
634
Re: McLaren MCL35M
Herr_Koos
Re: McLaren MCL35M
Excellent shot of the floor assembly! Wow, that's intricate stuff.
Owen.C93
Owen.C93
191
Re: McLaren MCL35M
Mark4211 wrote:
27 Mar 2021, 03:35
https://i.imgur.com/rkhC4NB.png
Source
The engineer mentioned it on the radio when Lando was complaining about some excess engine braking. It sounds like a toggle of some sort.
Re: McLaren MCL35M
Please post your FP, qualy or Race analysis in the Team Thread. Posts have been moved.
