You are contradicting yourself... why would they fit KERS if it would make them less competitive? KERS is optional this year, any team would only fit it if they can lower their laptimes. If they dont fit KERS the cars fitted with it will slowly catch up to them... That is assuming they are truly this fast to begin with. I think they are running light, but are still kinda fast anyway. If will be fun to see if RB & JB still have the racecraft to race upfront.marinopc wrote:If they're not running KERS I think that's why they can go that fast. They can move an extra ballast of about 30 kg (KERS weight) wherever they want. I think once they have the KERS fitted, the car will be less competitive. I'd love to see Brawn on top, I think they deserve it after a tough winter.
Brawn GP has still produced a full width wing, but effectively the wingtip curls down to form the bottom half of the endplate, rather than an endplate being formed by vertical fence added to the wing tip. To meet the rules a large vane has been added to the foot plate to create sufficient side profile area.
Having no endplate makes the high pressure flow above the wing tip spill down the sides and around the front wheel, which also usefully reduces drag, offsetting the negative impact of the wider wing.
Beneath the raised chassis is an innovative feature in the form of a snow plough solution, similar to that sported last week by Williams. Starting from the splitter, a curved horizontal vane rises up to pick up the airflow passing under the nose.
As bargeboards in their conventional location are banned, the only place to put a vane is under the raised part of the chassis. Thus the Brawn GP solution is effectively a bargeboard mounted on its side.
The tumbling vortex of air spilling off the edge of the plough heads under the raised floor of the sidepods and feeds the diffuser higher pressure air. This allows the diffuser to flow more air and hence create a lot more downforce. This might be a critical feature in the BGP 001's pace.
Even with this device the car also sports small turning vanes mounted just ahead of the sidepods.
The car also appears to exit hot air under the gearbox fairing and rear crash structure, as part of a complex diffuser solution.
I heard (I believe it is James Allen said so) BGP 001 is slower by 8 kph on straight than F60Afterburner wrote:Anyone has information about top speeds on test? It would be interesting to compare top speeds with their times.
Barcelona, quite logicallyAfterburner wrote:That's interesting... Without kers and with a mercedes engine that is similar to ferrari only loses 8 kp/h. By the way, wich circuit was that measured?
timbo wrote:Barcelona, quite logicallyAfterburner wrote:That's interesting... Without kers and with a mercedes engine that is similar to ferrari only loses 8 kp/h. By the way, wich circuit was that measured?![]()
JA said that this difference is down to KERS, however different aero may give that much easily.
there is no more canada.Afterburner wrote:timbo wrote:Barcelona, quite logicallyAfterburner wrote:That's interesting... Without kers and with a mercedes engine that is similar to ferrari only loses 8 kp/h. By the way, wich circuit was that measured?![]()
Sorry, the way that BGP is performing made me forget that they only have tested at one circuit![]()
Considering the long main straight, the aero efficiency required for barcelona and without kers extra top speed it has to be aero related. Catalunya also needs a little bit of good mechanical traction for the new turns and the old 6 and 7, from this point of view BGP it's well prepared for most of the races except, in my opinion, Melbourne, Canada and Monza because they are stop and go circuits, we have to wait to them.
The greater benefit of Bargeboards was the increase in pressure and its distribution ahead of the leading edge of the underfloor (that then goes under the floor).ISLAMATRON wrote:Scarbs says "feeds the diffuser" but this is not exactly correct is it?... it goes over the top of the diffuser but also on the bridge wing which is also very effective is it not?
Is Scarbs saying that air from the sidepod inlets is exhausted through the U shaped section within the diffuser?
Felipe Massa said that Ferrari thinks BGP have been testing with ballast...ISLAMATRON wrote: You are contradicting yourself... why would they fit KERS if it would make them less competitive? KERS is optional this year, any team would only fit it if they can lower their laptimes. If they dont fit KERS the cars fitted with it will slowly catch up to them... That is assuming they are truly this fast to begin with. I think they are running light, but are still kinda fast anyway. If will be fun to see if RB & JB still have the racecraft to race upfront.
