etusch
131
I can't believe this. A formula 1 car's part must handle this kind of things. So powerful engine will vibrate. Drivers use kerbs, vibrates and track suface are not smooth as well.
so how someone can talk about this cars if engine is not vibrating so much, it runs smooth.
dans79
267
etusch wrote:
17 May 2021, 17:10
If a frequency is close to the resonant frequency of some component that could be very problematic.
197 104 103 7
I mean it's a return to the same issues that plagued them trying to run the tiny engine back in the mclaren days, same thing, issues with misfires, issues with connections from vibration, and issues on the gearbox. Can't all be pure coincidence.
Lock2nl
Where is the proof that they actually have a vibration problem?
These urinalists... There is a frequency problem, it's a very stiff block. I mentioned that the stiffer you make something the more frequency it can transmit vs something less stiff which can partially attenuate those frequencies. There is a vibration issue, it's being resolved, at the ICE level.
There's light at the end of the tunnel, we'll see what happens this weekend on Tsunoda's car.
Frankly I have no idea how they learned about this, but if it's the same way I did. It's 85% legit, and 15% got lost in translation.
ERS replacements had nothing to do with the vibration though, that's complete hogwash.
Lock2nl
godlameroso wrote:
17 May 2021, 18:59
So all teams somehow have to handle these vibrations?
Lock2nl wrote:
17 May 2021, 19:51
godlameroso wrote:
17 May 2021, 18:59
Do all teams run Honda ICEs?
PhillipM wrote:
17 May 2021, 18:13
What issues? Misfires, connections from vibration, gearbox? There are no issues of that kind.
There is no proof that they actually have a vibration problem. Just one Italian site published this story and there is
no other F1 site who writes about vibration problems with the Honda PU. Coincidence?
dans79
267
17 May 2021, 20:19
PhillipM wrote:
17 May 2021, 18:13
Are you referring to now or in the past, because they definitely had many issues in the past.
197 104 103 7
dans79 wrote:
17 May 2021, 22:10
17 May 2021, 20:19
PhillipM wrote:
17 May 2021, 18:13
Now, this saison.
17 May 2021, 20:19
Lock2nl
godlameroso wrote:
17 May 2021, 19:58
Lock2nl wrote:
17 May 2021, 19:51
godlameroso wrote:
17 May 2021, 18:59
No. I bet all blocks are stiff...
zibby43 wrote:
16 May 2021, 23:32
The Honda PU is suffering from vibration issues. This is what was causing the electronics problems. The PU has had to be turned down slightly to prevent more failures. Something that can hopefully be addressed for '22, as some of the components brought forward to '21 were theoretically best-suited to be fully exploited next year.
Excerpt:
"Vibration problems led to the replacement of parts of electronic components , such as the battery and the control unit on Perez's cars and the two Alpha Tauri, and above all a less aggressive use of the hybrid part of the Japanese unit compared to the first round of the season."
https://www.formu1a.uno/le-vibrazioni-d ... -red-bull/
Hopefully a driveline problem more than an inherent vibration stemming from the combustion.
etusch wrote:
17 May 2021, 17:10
They had vibration issues before. Discussed at length if you are willing to dig up posts from 2017 :D
etusch
131
18 May 2021, 14:42
etusch wrote:
17 May 2021, 17:10
I remember that. But that was both light weight and unmature combustion issues together. They firstly saw vibration when pu meet with McLaren gb.
But now pretty mature combustion process, way better intagration with chassis comprared to McLaren and this is zero concept more than lighter one. So I don't think there is not unacceptable vibration there. I am sure that if there is, still it is not comparable with McLaren one.
It wasn't really a lightweight issue before, PU weights are mandated.
Still they're showing the exact same problems as they had with vibration issues back in the Mclaren the last time they tried a tiny PU
