Alpha Tauri AT02
F1NAC
172
Re: Alpha Tauri AT02
Inside the airbox
aerofoilf1
aerofoilf1
247
michl420
michl420
Tsunodas Q1 crash show again that the Red Bull gearbox is a extrem lightweight product. Incredible how much the whole rear end vibrates.
Zynerji
112
michl420 wrote:
19 Jun 2021, 15:12
I think we would have seen that in any manufacturers gearbox in an identical incident... He was sliding at an angle to the pavement surface, so the tramping seen was more of a left-right-left-right loading/unloading scenario than a weak gearbox.
via motorsport.com
Sieper
73
michl420 wrote:
19 Jun 2021, 15:12
I too call BS (sorry) look how uneven that creamwhite surface was. Like a mogul skying track a bit. That caused the whole car to buckle from bump to bump.
michl420
michl420
Sieper wrote:
19 Jun 2021, 21:31
michl420 wrote:
19 Jun 2021, 15:12
I don't say it is bad. Just surprised to see such thing. It was meant as a compliment.
via @xavigazquez
Zynerji
112
What is the red fluid seeping out of the holes of the plank?? :shock: It wouldn't be Loctite, would it? Red hydraulic fluid?
Seeing the spark-scorch trails emanating from the leading edge titanium block is sweet as well! Thank you!
ScrewCaptain27
577
Zynerji wrote:
22 Jun 2021, 14:29
I think it could be some sort of adhesive or a fluid used in manufacturing. Doubt it is hydraulic fluid.
- Serj Tankian
Zynerji
112
ScrewCaptain27 wrote:
22 Jun 2021, 17:54
Zynerji wrote:
22 Jun 2021, 14:29
Conspiracy theory:
They used red Loctite to attach the plank right before going to the grid. Then the low pressure zone under the car after race start was strong enough to draw it out around the fasteners at speed. It might require an opening at the leading end of the thread to create a fluid interaction effected by the pressure differential.
Thoughts?
Sieper
73
Why? If the plank comes undone it is race over. Or were you merely seeking an explanation for the fluid being there?
This type of hole was very popular in years past, i assumed the regs had closed the option.
Still AT managed to put a small one in there.
Via Motorsport.com
_cerber1
275
