Red Bull RB16B
Sieper
73
Re: Red Bull RB16B
Well, they did ask for the part back (during FP) and these 3 races come quick and heavy after Max crashed a FW twice in Baku. So I think they simply don’t have more and Max get’s it. Either as it is better or suits him better. At least, consistent, not switching between wings all the time, making you have to adjust all the rest as well. That is valid for both drivers.
Austria is also a FW eater with those yellow kerbs. And they do that twice now in two weeks.
Re: Red Bull RB16B
Sieper wrote:
23 Jun 2021, 16:42
And there is a cost cap too. A new wing is many thousands of pounds. Hardly surprising they wanted the bit back from the marshal.
Pyrone89
Re: Red Bull RB16B
Sieper wrote:
23 Jun 2021, 16:42
How do they even fix that? The piece was completely broken off. Surely glueing it on will not withstand the forces of F1?
F1NAC
164
Re: Red Bull RB16B
Just_a_fan wrote:
23 Jun 2021, 16:46
Sieper wrote:
23 Jun 2021, 16:42
My thinking is that Wheatley was just sarcastic with Massi.
They could easily 3D print it in the box
RZS10
359
Re: Red Bull RB16B
Didn't they actually call a short VSC in order to retrieve that part?
If you look at all the car parts over the course of the season then it's quite normal to just cut out certain pieces in order to replace them with others, so they absolutely do have a way to bond those parts together.
Big Tea
Re: Red Bull RB16B
Pyrone89 wrote:
24 Jun 2021, 10:42
Sieper wrote:
23 Jun 2021, 16:42
It means no one else can study it
TimW
TimW
36
Re: Red Bull RB16B
Pyrone89 wrote:
24 Jun 2021, 10:42
Sieper wrote:
23 Jun 2021, 16:42
Perfectly possible to repair that. At a corner like where it broke, the strength is depending on the resin. If you repair with the same resin, maybe some overlaminate at the surface (grind away first a bit so it does not end up thicker), will give you similar strength.
The fact that it snapped of quite cleanly, without too much frayed fibers etc., indicates that it is quite easy to repair. On a section where the fibre strength is really used, the fracture will be much more explosive, and repair will be much more difficult.
Sieper
73
Re: Red Bull RB16B
I watch all FPs. Just relaxation and I love it. To follow how the weekend develops. But they did show, I think during FP3 a guy walking with a repaired front wing in Max’ box. The new repaired part was faired in about halfway up into the existing side plate. You could easily see this as the upper part was still dark blue, white sponsor logo and then halfway down it was Black carbon. Also some (two I think) of the upper Louvres of the wing part itself were Black/replaced.
So I confirm they did exactly as TimW explained above.
Re: Red Bull RB16B
Spielberg
Via AMuS and @AlbertFabrega
etusch
131
Re: Red Bull RB16B
TimW wrote:
24 Jun 2021, 13:38
Pyrone89 wrote:
24 Jun 2021, 10:42
Sieper wrote:
23 Jun 2021, 16:42
I've read an article about formula 1 composite tech. It was include interview with a composite supplier partner of formula 1 teams who was saying they work on both carbon fiber and resins to allow same or more strength with lesser layer. To achieve this you have to develop especially resin and its features. Reparing a carbon parts is very common and acceptable. There is always a possiblity to have failure somewhere of parts then need to be repaired. You can not send garbage such an expensive thing. Not only after breaking it during fp session but during production I believe they do repair jobs.
Re: Red Bull RB16B
Nicolas Carpentiers wrote:On the RB16B, Red Bull has now extended the serrated trailing edge to the full lenght of the diffuser flap (not only in the corners). It seems to be made of carbon.
Scarbs wrote:Developments on Red Bull diffuser. The metal steak knife sections are now much wider, with a third serrated trailing edge added in the middle.
Capharol
Capharol
21
Re: Red Bull RB16B
these are hidden chainsaws to scare off the opponents :D
Shandow
Shandow
Re: Red Bull RB16B
Red Bull RB16B New Diffuser
epo
epo
-6
Re: Red Bull RB16B
Morteza wrote:
24 Jun 2021, 20:22
https://pbs.twimg.com/media/E4qYJwsX0AU ... ame=medium
https://pbs.twimg.com/media/E4t8lhYWYAE ... ame=medium
https://pbs.twimg.com/media/E4qma9zWUAI ... name=large
They look pretty sharp, looks dangerous might be a ban incoming :D
Zynerji
109
Re: Red Bull RB16B
TimW wrote:
24 Jun 2021, 13:38
Pyrone89 wrote:
24 Jun 2021, 10:42
Sieper wrote:
23 Jun 2021, 16:42
So, they are designed to be easily repaired? I never considered this, but it seems obvious in a cost cap environment.
