Ferrari SF21
ryaan2904
ryaan2904
Re: Ferrari SF21
codetower wrote:
Mon Jul 19, 2021 3:17 pm
Question regarding the tyre degradation issues in the SF21: The team say they still haven't solved the issue, yet the car/tyres seem to be performing much better since France. Have the drivers made any significant changes to their driving styles to help with the tyres? If the team hasn't "fixed" the problem, they definitely have improved it quite a bit.
When did they say that? I think its mostly solved for hotter temperatures. Maybe not for colder tracks tho..
codetower
Re: Ferrari SF21
ryaan2904 wrote:
Mon Jul 19, 2021 6:07 pm
There was a quote from Leclerc over at scuderiafans that the team has not yet solved the tyre issues from france despite the strong British finish.
https://scuderiafans.com/ferrari-have-n ... lverstone/
hape
hape
Re: Ferrari SF21
And we don’t know the influence that comes from the new rear tyres. Might be small difference but over race distance it can be substantial if it helps one team but is a disadvantage for the other.
ryaan2904
ryaan2904
Re: Ferrari SF21
codetower wrote:
Mon Jul 19, 2021 6:19 pm
This is worrying :oops:
ryaan2904
ryaan2904
Re: Ferrari SF21
hape wrote:
Mon Jul 19, 2021 7:12 pm
Yea i think they helped Ferrari out too. Lets see what happens in hungary, that'll be a confirmation.
f1316
f1316
135
Re: Ferrari SF21
ryaan2904 wrote:
Tue Jul 20, 2021 6:27 am
I’d say the opposite: if the performance can be as good as it was without having solved the issue, it’s great news to see that they expect a further step once they fully understand the issue.
FerrariF60
FerrariF60
Re: Ferrari SF21
by the time they solve the issue.....seasons over....that's how fast ferrari gets on top of things
codetower
Re: Ferrari SF21
FerrariF60 wrote:
Wed Jul 21, 2021 2:13 am
Ha! Well, considering how they've gone from tearing up the tires and dropping hard out of the top 10, to a podium finish in about a month, I'd say they are pretty fast.
JPower
JPower
Re: Ferrari SF21
Ferrari knows what the problem is ie front axle slip and the car not putting enough energy into its front tires. They just won't be able to do anything this season beyond minimizing its issues through setup.
F1NAC
176
Re: Ferrari SF21
Wasn't there a mention of a issue with rim design which is homologated or something this season and cannot be changed?
hape
hape
Re: Ferrari SF21
F1NAC wrote:
Thu Jul 22, 2021 1:14 pm
Yes, was in an interview with Binotto. Apparently the rims can not be redesigned this year.
Re: Ferrari SF21
New rear tires are easier to keep in the window, this helps out at front because you can force a little bit more slip angle on the rear axle without roasting the tires. This helps if you have a little understeer at the front axle, but it changes driving style slightly. Nothing the drivers can't adapt to in a few laps.
ryaan2904
ryaan2904
Re: Ferrari SF21
godlameroso wrote:
Sat Jul 24, 2021 3:15 pm
Helps out leclerc anyways since he prefers oversteery cars
Re: Ferrari SF21
ryaan2904 wrote:
Sat Jul 24, 2021 4:22 pm
If it's like what I'm experiencing with a certain tire I'm using, it's that the relationship between throttle and rear axle rotation is a bit more "transparent". Like the older tire had more contact patch deflection so the peak grip loss was more sudden because it wasn't just slip it was the contact patch shrinking as well.
In other words the path that leads to total grip loss has fewer brush and cobwebs in the way, it's more defined, so to speak. So it lets you hang out the rear end just a little bit more, and this is especially useful in say turn 5 and 9 in Hungary.
ryaan2904
ryaan2904
Re: Ferrari SF21
godlameroso wrote:
Sat Jul 24, 2021 4:29 pm
Nice read =D>
