2021 Mclaren F1 Team
Emag
Emag
Re: 2021 Mclaren F1 Team
We can't be sure that McLaren's inherent low speed weakness is due to their suspension design.
McLaren used to be one of the best teams, mechanically, a couple of years back. And to be honest, the 2017 car was quite decent for its time as well (they were good in Monaco, Singapore and Mexico).
The low speed weakness could just be a compromise of their current concept. They have pretty good traction I would say, so they definitely know how to make a decent suspension (at least in the rear).
Developer of F1InsightsHub
the EDGE
the EDGE
68
Emag wrote:
12 Aug 2021, 11:33
No we can't, but suspension is much more than traction, which is more about corner exit. Corner entry is just as important (as we know for Daniels struggles), how the suspension handles the transition, especially around body roll and keeping a stable platform, and of course how it handles kerbs
I suspect Mercedes & Redbull set-ups are far better at this (front & rear) giving them a big advantage. Hopefully the new regs will go some way to equalising this a little next year
runningmanz
runningmanz
Great look back at the last 10 years with Ricciardo in F1. So many awesome moments. Hopefully many more to come with McLaren!
https://www.formula1.com/en/latest/arti ... AEH6s.html
cliffgamerz
cliffgamerz
runningmanz wrote:
13 Aug 2021, 08:48
For me till date and beyond his 2014 season will always be remembered because of not just for beating up his 4 time drivers championship teammate but he was the first and the only driver on the grid that season to beat the two Mercedes drivers in Hybrid era, and i don't think he lost his driving style and i know he would be back at top very soon. Also many underestimated Lando to be tough competitor to him but they are evenly matched and will be good driver lineup like Ferrari currently have.
mwillems
https://the-race.com/formula-1/what-mak ... to-master/
More from Seidl about DRs struggles, reiterating that the issue for him with this car is the inability to carry speed into the corner, and not with trailbreaking per se, as actually doesn't want to break so much.
-Bandit
flmkane
flmkane
mwillems wrote:
13 Aug 2021, 15:53
That's a really good article but I need some help wrapping my head around it.
The current McLaren likes to brake late and then corner with a high yaw rate? Yet the front end is weak?
How does that happen? If the front end is weak its supposed to be slow in yaw.
Also, of the characteristics that stood out to me (brakes late, rotates fast, apply throttle fast, weak front end), most of them sound like an Adrian Newey or Rory Byrne approach to building a fast car. Except the weak front end. Schumacher, Kimi and Lewis drove like that. Did Mika as well?
This sounds to me like the car behavior carried over since about 2009. I hesitate to give an earlier date, but even Montoya said that his McLaren felt as if "the steering wheel isn't connected".
Also, the extremely stiff suspension (even by f1 standard rds) has been a McLaren feature since about 2009 also (plus or minus a year). Same with the lack of low speed traction. Back then I though it was the lack of a double diffuser. Then I put it down to an inferior exhaust blow diffuser. But the low traction characteristic has remained throughout the successive generations.
I could probably make a stronger conclusion if I knew how to compare the lines that Lando and Ric take but I lack the skill to eyeball that. Suggestions for doing such an analysis?
Jolle
Jolle
133
flmkane wrote:
13 Aug 2021, 19:19
mwillems wrote:
13 Aug 2021, 15:53
Reading the article, it looks like McLaren lacks the ability to keep all the aero at the apex when you go from brake to throttle, having to drive the corner more in a V then a U. Thinking of it, VET had his own problems going from RedBull to Ferrari and never looked like to have the same feeling in the car for those low/medium speed exits. Could just be that RedBull has a less compromised chassis then McLaren (which isn’t strange seeing the difference in resources)
flmkane
flmkane
Jolle wrote:
13 Aug 2021, 19:51
flmkane wrote:
13 Aug 2021, 19:19
mwillems wrote:
13 Aug 2021, 15:53
HAH! Maybe Ric should just throw out the wings and go drifting? (jk jk, the pirellis would melt)
Seriously though I don't think that behavior is a compromise, rather an artifact of an old design philosophy.
mwillems
flmkane wrote:
13 Aug 2021, 19:19
mwillems wrote:
13 Aug 2021, 15:53
All I can get is it isn't very good at the transition but it only gives you the variables in the corner that affect it, not the reason. The aero stops working well in the transition so the transition needs to happen before the corner and the way to do this is to scrub speed first enter the corner and then push out.
Those factors you mention can all affect it.
We do know that they made the front wing larger so that it would not bottom out as much if it were too close to the floor, so we can assume that this was/is part of it. Not necessarily for front grip but possibly when the front wing unloads they suffer Y250 degradation.
I don't think it would be crazy to think that in the transition to acceleration from braking, whilst turning, perhaps they are struggling to keep the floor sealed and it might take a little too long for that transition to complete and for the car to regain the traction to pull out of the corner.
Imagine a car that does what you expect going into the corner, feels stable, then as soon as you place your foot and the go pedal it starts losing rear grip and you can't accelerate your way out of the corner until your fully in a straight line. I have a feeling this is what he is experiencing.
I don't think it is a problem with he mechanical parts of the car, but how they are set up to work in tandem with the rake of the car and how the car moves under braking, which should be to try and lift it's nose up or slow the descent of the nose, and under acceleration where it should try and keep keep the nose down, or slow the nose ascent - contrary to what the nose would really like to do in those situations.
If the car has striking behaviours in those two moments then you could assume that the car loses front loading briefly and therefore loses the some of the floor seal and huge whack of downforce.
As the article suggests though, it's not a flaw because you can adapt a style to suit it and make it go fast, the issue here is that Daniel struggles to do that.
The concern is that they do not know it will be gone for next year either, according to Seidl, as they are not sure it is just a trait of their methodology and they also don't think it is a problem for the car as it is a fast car.
No point panicking now though, time will tell. Since Mclaren will likely be his last shot, I hope he isn't being stubborn but I genuinely feel like that may be a part of it, despite him saying otherwise.
There was a time in the past where Lewis Hamilton had to break earlier in his Merc when coming off from DRS, because it took a moment for the rear wing to load back up and it wasn't straight away. He'd dab the brake, carry speed and then brake in earnest, so that the rear was fully loaded as he entered the corner. The aero of the car was so complex that it took a moment for it to settle back down and reload under the DRS-Braking transition.
it reminds me a little of that.
-Bandit
mwillems
mwillems wrote:
28 Jun 2021, 09:30
JordanMugen wrote:
28 Jun 2021, 00:45
mwillems wrote:
28 Jun 2021, 00:00
Is he chasing a way to make his style work rather than adapting and doing what Lando does, in the belief that ultimately he can find a faster way through and he doesn't want to compromise?
Would it be a simplification to say the McLaren needs a V-shaped corner profile (braking in a straight line, turn the car hard, throttle in a straight line), whereas Ricciardo is trying to drive a classical U-shaped corner profile? :)
No, because he is doing a V already.
Point is it looks like in turn 9 and 10 that he could slow his entry to the corners more to allow him to keep more speed mid corner and to find the exit earlier, but is choosing not to. As to why, I don't know.
In sectors 1 and 2 he starts and finishing braking at the same time as Lando, but slows less, which does seem to be feel for the brakes. But then they still seem neck and neck anyway, so perhaps that's not important.
But in sector 3 it seems to not be about braking technique, it appears to be a choice. He could dab the brake in turn nine but doesn't, and takes an age to rotate and visibly loses time.
I found my original post about this from Austria, there are a few others at that time, including several posts about how all the cars seem to benefit from scrubbing speed before the corner. I did also post an article that did analysis between Max and Sergio, because it was talking about how Max scrubbs the speed before the corner and that is how he gains time on Sergio. Much like the difference between Lando and Daniel, but that was deleted.
I might try and find it again on the basis that hopefully the mods can see that it is relevant to this discussion as the traits they discuss are comparable.
-Bandit
mwillems
https://www.gpblog.com/en/news/89810/ho ... early.html
I think this was it, lets see if it lasts. I have no sound on my PC right now so I'm not sure if it was the one.
-Bandit
Mclarensenna
mwillems wrote:
13 Aug 2021, 15:53
Very detailed article.
"Andrea Stella, suggests the problem is Ricciardo is from the “opposite end” in terms of driving style"
So basically the car is the complete opposite of what Ric likes. No wonder he is struggling so much.
"Stella points out the lack of testing opportunities has made this problem harder to get on top of. Ricciardo had just a day-and-a-half in the car pre-season and since then has done his learning on race weekends."
"But this has to fit in with the usual work of the race weekend and can’t waste time doing needless experimentation"
So basically no time to test even on a race weekend. Ric sure has his work cut out for him. It is looking very unlikely he will be fully up to speed with this car until at least next year based on that article.
Ayrton Senna: Pure driving, pure racing, that´s what makes me happy.
mwillems
Mclarensenna wrote:
14 Aug 2021, 12:13
mwillems wrote:
13 Aug 2021, 15:53
Its important to note that Seidl puts a grey blanket over when the car had this trait to make it harder to say that Carlos did it so why can't Danny.
There are definitely elements of protection and they may be true, or not. But you'll not see Carlos get involved, he's a gent. So we have to give him the benefit of the doubt in my mind and support his work for Mclaren.
Like I've said before, silver lining here is a huge boost of confidence for Lando who is going from strength to strength after beating a contender on fair terms.
A third year of being the second fastest driver would be tough.
I think Daniel will provide many benefits on and off the track so I'm good with where we are at.
-Bandit
the EDGE wrote:
10 Aug 2021, 11:57
CjC wrote:
10 Aug 2021, 11:36
With the news that Ferrari will bring a PU update later in the season... where are Mercedes at regarding any updates? Have the already updated what they can?
Merc have said several times that they expect to make gains on the PU side this year.
I have no idea if they have already been realised in the past month or so, or if that even means upgrades, but in light of what Ferrari said I suspect it does, & I hope they’re still to come
The PU are locked down for the rest of the year. Only thing it can be it lubricants, fuel or software. I read that update and it sounded like mumbo jumbo to me. Only 1 more PU iteration left and that will be for the start of the 2022 year. After that it will only be reliability upgrades.
mwillems wrote:
14 Aug 2021, 15:50
Mclarensenna wrote:
14 Aug 2021, 12:13
mwillems wrote:
13 Aug 2021, 15:53
None of this really matter anymore. McLaren seem to be slotted in for either 3ird or 4th in the championship, 2nd was never a possibility. Think they'll be happy with both.
With regards to the car's traits(how to drive it to get the most of it), they will NOT go forward. All new suspension (front and back) with no hydraulics and different wheelbase. The aero will be completely different, so both drivers will be starting from scratch.
