Mercedes AMG F1 W09 EQ Power+
Re: Mercedes AMG F1 W09 EQ Power+
Just_a_fan wrote:
25 Aug 2018, 10:20
They have a larger number of thinner spokes and made the parts of those spokes nearest the point of contact with the hot hub thinner (by adding a hole in it). That all points to them trying to prevent heat getting to the tyre. If you wanted to get the rim hot, you wouldn't make the connections to the rim thinner, would you?
The new rims seem to have more surface area to take away heat. The change probably brings more consistent tire temperatures with them.
Flanker27
Flanker27
-2
TV images showed how flexible the rear wing is compared to all the others team.
Look mercedes on Spa chicane curbs, the whole rear wing shakes
dans79
267
Mercedes needs to figure something out so they can regain the power advantage.
202 105 104 9 9 7
GPR-A duplicate2
64
dans79 wrote:
26 Aug 2018, 16:06
I don't think that is a possibility as the last spec engine is out for the year. May be for next year, there is a definite possibility, when they would have clearly understood the Ferrari trick (I said this earlier too). It's their extra down force levels today that sort of let them down, which played a critical role yesterday. I don't think they would run the same wing in Monza.
It's about the chassis development that can play a role for the rest of the year.
Big Tea
99
GPR-A wrote:
26 Aug 2018, 17:08
dans79 wrote:
26 Aug 2018, 16:06
It is the decision if they squeeze more out of the motor or make sure it lasts until the end of the year now.
I would not have to make the call
roon
roon
412
dans79 wrote:
26 Aug 2018, 16:06
*this season really ought to be more boring, imo*
dans79 wrote:
26 Aug 2018, 16:06
Traction problems too. Time for high rake?
roon wrote:
26 Aug 2018, 17:41
dans79 wrote:
26 Aug 2018, 16:06
You're boring with your attempts to suggest everyone with a contrary opinion to yours is a fan of a driver/team that is not your favourite. In short - troll. Go away.
PlatinumZealot wrote:
26 Aug 2018, 21:56
dans79 wrote:
26 Aug 2018, 16:06
Yeah, they'll have working by the next race... :roll:
Flanker27
Flanker27
-2
GPR-A wrote:
26 Aug 2018, 17:08
dans79 wrote:
26 Aug 2018, 16:06
The only trick nowadays is mercedes rear wing flexibility.
Or maybe what you call "trick" is the fact that this year mercedes cannot burns tons of oil? Well, that was a real trick, but was made in Brixworth...
jh199
32
What would a flexible rear wing accomplish exactly? Wouldnt it just disrupt the flow on the underside of the wing exactly when they need it most?
Heres a good video about it btw https://twitter.com/Vetteleclerc/status ... 2216473605
thisisatest
thisisatest
Just_a_fan wrote:
25 Aug 2018, 10:20
My guess is that the thinner spars transfer heat from the hub area to the rim area more gradually. Smaller temperature spikes. Curious how the rim is shaped inside the tire...
JesperA
JesperA
Does the rear wing really wobble like that on a regular basis and consistently? It may just be the resonance frequency from hitting the curb or any other way of inducing an oscillation matching its natural frequency. Bits and pieces have vibrated/wobbled from time to time during F1 entire history, almost never by design though, just from a bunch of circumstances resulting in a part hitting its internal resonance frequency. Flutter is also fairly common in any object passing through a fluid (most commonly water and air)...So, if it does not wobble like that on a regular basis it's most likely not by design or any malicious implementation by Mercedes.
Big Tea
99
Who knows, they may have found a problem Mercedes was looking for but could not find.
RZS10
359
I know that this is a very simplistic drawing without proper labels for the forces and it ignores the car squatting in corners and some other forces...but
bottom:
Let's assume the car is cornering (to the right) with a very stiff wing, the downforce acts, well, downwards, the load on the tyres isn't equal since it's transferred to the outside tyre (left rear) so you're not utilizing the inside tyre as much as you could.
top:
With a wing which pivots you'd partially counter the car's squatting and the downforce would slightly counteract the uneven load distribution meaning more grip.
Whether that wing is tilting enough to have any positive effect in fast corners which the uncontrolled wobbling wouldn't nullify in slow corners is another thing to consider
