Mercedes GP MGP W01
JohnsonEvilTwin
JohnsonEvilTwin
Re: Mercedes GP MGP W01
There definatly appears to be a stalling device on the rear wing, How the wind is tunnelled appears a bit of a mystery.
It will also need to be controlled as going through fast corners with a stalling rear wing WILL be catastrophic.
"In the beginning the Universe was created. This has made a lot of people very angry and is widely regarded as a bad move." Adams
7TTT
Maybe the duct only gets air if the car is on straights?
Darknight
Darknight
Well if you take a look at this picture you can see that the end plates are "fat" in the middle.
Also on this drawing it can be seen.
http://www.formula1.com/news/technical/ ... 8/693.html
biggles22
biggles22
Darknight wrote:Well if you take a look at this picture you can see that the end plates are "fat" in the middle.
They aren't fat, they just have a recess in them. Look at the outside of the endplates, especially where the bridgestone logo is, you can see the curve in.
Confused_Andy
Confused_Andy
Surely that wing design if for strength, thicker in the middle would mean its more rigid and prevent flex.
siskue2005
siskue2005
70
i think this is how its been fed
What do you guys think? 8)
korzeniow
korzeniow
siskue2005 wrote:i think this is how its been fed
I think that might be the case.
February 5, 2013
bugref
bugref
not enough, I am still looking for the changes of their nosecone and front wing, hope they revamp that design. cant wait for the European if nothing changes then goodbye for schumacher. might as well watch the motogp and WSBK...
PNSD
PNSD
Nope, isnt that where the rear wing can be adjusted? Bought to the car at the Belgium GP last year.
raymondu999
Yeah AFAIK that's the "pinhole" where you can adjust the wing angles. Brawn (at least last year) had the car only adjustable on the leading edge while the trailing edge was constantly at maximum height.
失败者找理由,成功者找方法
Pandamasque
PNSD wrote:Nope, isnt that where the rear wing can be adjusted?
Exactly. Besides the 'piping' goes all the way down the endplate:
siskue2005
siskue2005
70
so my theory is out...... but from where does it get the air??
its really a mistery :x
siskue2005
siskue2005
70
cool.....that piping brings air to the wing
but from where does it take the air?
forty-two
I think that what you're seeing there is a pitot tube for sensing airflow somewhere, and they've chosen that snaky route up the endplate in order to reduce the disruption to the airflow as a result of the tube being taped there.
I would have thought that that tube is way to small to perform any useful blowing function, unless it's fed from a compressor of course!
7TTT
look at this..
http://www.f1fanatic.co.uk/wp-content/u ... i_2010.jpg
silver tube around the sidepod
