Afaik Eau Rouge is the Left-Right one.Just_a_fan wrote:Eau Rouge is the simple left hander at the bottom of the hill. The tricky climbing right hander is Raidillon. Unfortunately common usage ignores Raidillon and calls it all Eau Rouge.raymondu999 wrote:I think the thing is that Eau Rouge is a left-right-left. There are two direction changes where having DRS on would imbalance the car due to less rear grip
Actually, the left-right chicane is Eau Rouge, the left hander after, at the top of the hill is Raidillon, and it gets ignored because it's way less tricky.Just_a_fan wrote:Eau Rouge is the simple left hander at the bottom of the hill. The tricky climbing right hander is Raidillon. Unfortunately common usage ignores Raidillon and calls it all Eau Rouge.raymondu999 wrote:I think the thing is that Eau Rouge is a left-right-left. There are two direction changes where having DRS on would imbalance the car due to less rear grip
Wikipedia gives no citation for this though, a quick look through the images on google shows that 90% of them refer to the left and the right as eau rouge, and the left again as raidilon. I've been trying to load the spa webpage's map to see what they say, but it appears to be horribly broken.dave34m wrote:I was at the circuit recently and saw a map in the pit building showing Eau Rouge as only the bottom of the hill. This is what it says on Wikipedia,
Properly speaking, the Eau Rouge corner is only the left-hander at the bottom. The following right-hander that leads steeply uphill, which was introduced in 1939 to shortcut the original hairpin "Ancienne Douane", is called "Raidillon"
This is the problem, modern interpetation says that Eau Rouge is Left Right but clearly Eau Rouge was the left leading to the old hairpin and Raidillion was the right hand bend that was added to remove the haip pin as they wanted to make the track fasterbeelsebob wrote:Wikipedia gives no citation for this though, a quick look through the images on google shows that 90% of them refer to the left and the right as eau rouge, and the left again as raidilon. I've been trying to load the spa webpage's map to see what they say, but it appears to be horribly broken.dave34m wrote:I was at the circuit recently and saw a map in the pit building showing Eau Rouge as only the bottom of the hill. This is what it says on Wikipedia,
Incorrect, sorry. Left hander is Eau Rouge, right hander is Raidillon and the left kink on to the Kemmel straight is unnamed.beelsebob wrote:Actually, the left-right chicane is Eau Rouge, the left hander after, at the top of the hill is Raidillon, and it gets ignored because it's way less tricky.Just_a_fan wrote:Eau Rouge is the simple left hander at the bottom of the hill. The tricky climbing right hander is Raidillon. Unfortunately common usage ignores Raidillon and calls it all Eau Rouge.raymondu999 wrote:I think the thing is that Eau Rouge is a left-right-left. There are two direction changes where having DRS on would imbalance the car due to less rear grip
