Vodafone McLaren MP4-27 Mercedes
Pup
Pup
50
Re: Vodafone McLaren MP4-27 Mercedes
Probably. I also doubt if the deflection is nearly so neat as what's shown in that diagram. I bet that the exhaust looks more like a vertical sheet than it does a line, where only a part of the exhaust is pulled down.
hardingfv32
hardingfv32
Any experts on the Conda effect. I question whether it is applicable if the flow in not initiated at a tangential angle. What I am getting at is the body surface at the exhaust tip must be at an angle of 15 degrees per the rules. This is an angle, not a radius. All the examples of Conda effect systems I have found are at least 0 deg.
Could this McLaren channel just be an form of a 15 degree cone to control the expansion of the exhaust flow? Keep a narrow focus as long as possible?
Brian
Pup
Pup
50
I'm pretty sure the exhaust outlet curves and begins tangent to the exhaust pipe.
hardingfv32
hardingfv32
But it can not per the 15 deg cone requirement. The angle forms at the very edge of the exhaust pipe opening. A distinct angle with no blending. I think this prevents the Conda Effect.
Brian
raymondu999
Don't forget you're mandated to have a perpendicular cut in the exhaust pipe too - of a controlled diameter
失败者找理由,成功者找方法
beelsebob
beelsebob
85
hardingfv32 wrote:Any experts on the Conda effect. I question whether it is applicable if the flow in not initiated at a tangential angle. What I am getting at is the body surface at the exhaust tip must be at an angle of 15 degrees per the rules. This is an angle, not a radius. All the examples of Conda effect systems I have found are at least 0 deg.
Brian
3°, not 15.
the EDGE
the EDGE
68
sejamesxy wrote:hey guys
here is the full view of the car
<youtube>
wow...it may be CGI but that's the best look at the 'snow-plough' I have ever seen.
I didn't realise it compacted the flow down like that
Reason: Removed video quoted from post above
beelsebob
beelsebob
85
<video>
It's just some news company's random 3D model, and not a very accurate one at that.
Holm86
250
<video>
Yeah. Sidepods looks nothing like the real model.
Tyler
Tyler
The bargeboards are wrong too.
gridwalker
gridwalker
The beam wing is wrong too ...
aral
aral
26
This appears to be the pre testing "plastic" car. Look at exhaust outlets. Totally different shape and size to those tested.
Owen.C93
Owen.C93
177
Their RB8 model has an 2010 diffuser and this MP4-27 model has the 26 rads still inside it. They aren't accurate and just used for demonstrative purposes.
beelsebob
beelsebob
85
sejamesxy wrote:How many radiators are you allowed in f1 car.
As many as you like, and can fit in.
hardingfv32
hardingfv32
beelsebob wrote:3°, not 15.
Please expand on statement.
Brian
