2025 Mercedes-AMG Petronas F1 Team
Hammerfist
Hammerfist
How is it possible that the factory Merc car is having all these failures and meanwhile customer Mclaren is completely trouble free?
Quantum
Seanspeed wrote:
02 Jun 2025, 18:37
A top team highly confident in their design and engineering will accomplish more with less simulation/windtunnel runs than somebody else.
I'll take resources over bravado.
"Interplay of triads"
Seanspeed
Seanspeed
Quantum wrote:
02 Jun 2025, 20:21
Seanspeed wrote:
02 Jun 2025, 18:37
It's not bravado, jesus christ.
There's earned confidence in a top team. When initial drafted designs work better out the gate than others, you simply need less simulation runs to validate them and get your desired result.
If a team that could very realistically fight for P2 in the championship internally determines that it should give up and tank the season to get 10% more windtunnel/CFD time, it's a massive insult to the engineering teams, basically saying, "Well you guys messed up too much to care about this project any further". And what reason do you have to think that 10% more windtunnel/CFD time is what is going to 'make the difference' and turn the next Mercedes into a championship leader? I think they either have a winning concept in the pipeline or they dont. That little difference in resources isn't gonna be make or break.
Lasssept
126
MB_Racer
MB_Racer
Yup and this is how Ferrari came back and got the second place from Mercedes 😨😨
Quantum
Seanspeed wrote:
02 Jun 2025, 23:25
Quantum wrote:
02 Jun 2025, 20:21
It really is.
I'll take every tangible resource available over an arbitrary made up requirement.
Waz
Waz
The resource restrictions are not nearly the game changer that some make it out to be.
Other than the amount of time actually spent in the tunnel or CFD, there are areas that are unrestricted, for example, cooling. This seems to apply to all cooling, not just engine, so includes brake ducts.
Everything about F1 is smoke and mirrors.
Waz
Waz
Quantum wrote:
03 Jun 2025, 08:15
Seanspeed wrote:
02 Jun 2025, 23:25
Quantum wrote:
02 Jun 2025, 20:21
It really is.
So you believe all engineers are equally skilled then and each team is putting the same quality of data and design through CFD and eventually the WT?
Quantum
Waz wrote:
03 Jun 2025, 13:08
What does skill have to do with confidence?
This is all wayyyyy off topic.
kurtj
kurtj
Waz wrote:
03 Jun 2025, 13:04
That's knee jerk reaction to one team's genius. F1 is still a playground for engineering creativity and trying clamp down everything to make it spec series is really stupid. There are other spec series' available for those who want absolute equality in equipment.
Mansell89
Mansell89
Canada seemed to suit the car reasonably well last season- any reasons why not this year?
Obviously McLaren is even better now so they’ll go well but would Canada be better for Merc and than Barca was?
OverheatedTurbo
OverheatedTurbo
Tyre temp. management is the team’s number 1 priority right now and making that new rear suspension work. Let’s see what solutions they bring for Canada and subsequent races. Still, running the same diffuser since Race 1 is strange…are there no gains to be had in that area?
Lasssept
126
AMuS
Mercedes has been plagued by the same problem since 2022. The tyres get too hot, especially when there is still a lot of rubber on the tread. It has improved this year, but the engineers still do not have full control over it.
In Barcelona, the tyres overheated on the left side, front and rear. The tyre only falls back into the window when enough rubber has been scrubbed off. Compared to the outliers in Jeddah and Imola, Barcelona was actually a small step forward. No other track stresses the tires to such an extent, especially with asphalt temperatures of 50 degrees. The engineers are still feverishly searching for a solution.
Initially, the new rear axle [upgrade], which made its debut in Imola, was suspected. However, it was removed again for Monaco and Barcelona. Wolff suspects: “It looks as if this problem is inherent to the car.”
https://www.auto-motor-und-sport.de/for ... barcelona/
Matt2725
Matt2725
Hammerfist wrote:
02 Jun 2025, 19:38
McLaren have a bespoke cooling package for their PU which is designed in house. It allows them to better cool the PU and you'll note, they often have smaller openings in the bodywork as a result.
Thing is, HPP will be fully aware of what McLaren are doing regarding cooling as their own employees are embedded within the customer teams, looking after the PU.
In theory, they could apply that knowledge to the works team but good luck getting it past the FIA I'd imagine.
Regarding Spain,
Russell's pace in the latter stages looked quite good all things equal. Both he and Max were actually catching Charles back up quite rapidly prior to their ding dong. Indeed even after that, Russell crossed the finish line very close to Leclerc.
Farnborough
Farnborough
152
Lasssept wrote:
03 Jun 2025, 13:54
AMuS
"]It looks as if this problem is inherent to the car" a "statement of the bleedin-obvious" if ever there was one :D for reference, this view is embedded within the annals of UK humour as comment about someone saying something so plainly obvious to every observer.
A big difference is the McL rear structure incorporating suspension etc ... unique to McLaren (no comparative usage) but appears to have absolutely nailed it in design and application. I believe its origins (conceptual layout) are from one J Key Esq that leads to this chassis layout, much vilified on their team thread, knows quite a bit about suspension theory along with advancing concepts in this field.
"The engineers feverishly searching for solutions" a funny statement too, they are supposed to be qualified in this subject, but instead appear completely restricted toward lucid appreciation of what may ultimately point their way out of this. There's no guarantee they'll get a clearer picture for next year either.
