Khamsin Virtual Racecar Challenge 2014
CottrellGP
CottrellGP
Re: Khamsin Virtual Racecar Challenge 2014
Hi All, i want to start some CFD on my car and to do some test! But.. i have no clue were to start or what i need to do first. Is there an easy setup guide for us newbies? Cheers Dan
Dan Cottrell
Master Of Innovation!
RicME85
52
Its dead simple and we have been through it before.
Just use the portal Julien has set up, I did yesterday, its as simple as loading the sketchup file and putting in a couple of numbers Julien posted in here a few pages ago.
CottrellGP
CottrellGP
RicME85 wrote:Its dead simple and we have been through it before.
Ah yes i seen that, didnt really understand what it was but now i do, how long did you wait for until you got the result back?
Dan Cottrell
RicME85
52
it took a while, uploaded the file at around 6pm and got the link to download the results at about 7am but it was easy to do and didnt use my PC to do the brain work. havent looked at the results yet as there was an issue with the Amazon server and it denying me access to the result file so had to get in touch with Julien.
CottrellGP
CottrellGP
RicME85 wrote:it took a while, uploaded the file at around 6pm and got the link to download the results at about 7am but it was easy to do and didnt use my PC to do the brain work. havent looked at the results yet as there was an issue with the Amazon server and it denying me access to the result file so had to get in touch with Julien.
Thanks man, just sorted it out and sent my car off!
Dan Cottrell
CottrellGP
CottrellGP
Another question for all the designers, is there any plugins that will help me model a front wing?
Dan Cottrell
CAEdevice
52
Hi Dan, I don't use SketchUp but I know that there are some plugins that are usefull if you need smooth surfaces (some of them have been listed in the previous pages or maybe in the KVRC 2013 thread).
RicME85
52
if your not already, sign up to the sketchucation forum.
loads of plugins there with videos to show you how they work.
also on there is a plugin that works like a store front, add that to sketchup then you can add other plugins through it.
curviloft is a favourite of mine.
RicME85
52
Currently having a Hangout chat with Julien about the portal.
Will report back once I have understood everything.
astracrazy
astracrazy
31
its important to remember with the portal you still need openfoam to run the case file that it creates for you - which you will need linux for. You can use virtual box for example to run linux within windows and then install openfoam there.
The portal works fine, but i haven't got openfoam running on my linux side (i haven't tried for a while, i haven't had time) so i haven't run a complete cycle yet. I'm not really up to speed with linux anyway
Dan: curviloft is a great plug in. especially once you know how to properly use it, so watch the tutorials.
RicME85
52
Well that was interesting.
I will stick to using the usual Sketchup + Khamsin method as I can get it running no problem.
Dan - Julien says he hopes to get your files to your soon.
If you want to get some figures from this method you will need to install this - https://bluecfd-singlecore.googlecode.c ... -setup.exe
You will also want this - http://www.mediafire.com/download/cm42k ... _Files.zip to add to the scenario file generated by the portal.
I have put the Hangout chat I had with Julien on Pastebin so you guys can read it and figure out how to get CFD results.
http://pastebin.com/TrXWQEyV
RicME85
52
Luke - you DONT need Linux.
Dan - Julien told me to tell you that he is available to chat online and screencast to walk you through setting Khamsin up
RicME85
52
Thought that it might be worth bringing some information over from the old KVRC thread seeing as this page is turning into a bit of a CFD setup area.
Hi there. Nick, great job for following this up and keeping the conversation flowing. If you want to contact me, try info@hibouscientificsoftware.com.au or post on http://www.cfd-online.com with [KVRC] I am checking it more frequently than F1Technical.
Re wind tunnel model: please download from: https://dl.dropbox.com/u/40499338/KVRC2 ... 180mph.skp. It has annotations to try to explain how to set things up. Nick, can you supply the wheel/suspension for them to run the simulations?
For the 2012 test run, I used the following workflow:
- Set the car up in a stand-alone model (i.e group the body and the wheels in separate groups, i.e 5 groups) and then group the car in a single group;
- Move the car so that the front wheels are aligned with the red "x" axis with the car facing downwards (in a top view). The lowest point of the wheel is set to 5mm below the ground plane (z=0);
- Open the root model and copy and paste the wind tunnel around the car.
The above workflow requires that the car boundary conditions are setup again, but it is easier than trying to copy and paste the car geometry. The model provided should allow the way described above or to copy and paste the car geometry.
If you want to run preliminary simulation, you can neglect the tyre rotation and just copy and paste the whole car into the body group.
Wind tunnel only:
180mph scenario: https://dl.dropbox.com/u/40499338/root% ... 180mph.skp
100mph scenario: https://dl.dropbox.com/u/40499338/root% ... 100mph.skp
100mph scenario with 3degree yaw: https://dl.dropbox.com/u/40499338/root% ... %20yaw.skp
To run a test to check the configuration, it will be easier to just run a test. Use: https://dl.dropbox.com/u/40499338/Khams ... mplete.skp for example. Load the skp file in SketchUp, activate Khamsin tool and right-click -> Analysis -> go (local).
With the wind-tunnel:
- Open the skp file;
- Paste or import the car - with the provided wind-tunnel skp file, paste the car into the car-body group so that the imported car is part of the car-body group in the wind-tunnel skp file;
- If you are not able to paste the car into the car-body group (but do ensure it is imported as a group), you will need to do the following:
+ Khamsin tool -> right-click -> Define -> Volume
+ left button press (i.e press but do not release) on the group in which your car is imported, this should display a local menu;
+ move the mouse to the entry "Volume 0" - it should get highlighted in red, and release the left button;
+ Do the same and select "Close"
+ right-click -> Define -> Boundary Conditions
+ double left click on the the group in which your car is imported, this should display the boundary condition panel;
+ Change the name to "car" and the mesh size to "0.01"
+ Select "Close" by left button press over the group, etc.
- Then you can run the analysis: right-click -> Analysis -> go (local)
1. swak4Foam: it would be required for the wheels - to account for the rotation of the wheels. If you do not include the wheels, you can just untick the box.
How to install it? I am using the blueCFD distribution, which includes swak4Foam. blueCFD-SingleCore is a free subset of blueCFD, which does not include swak4Foam. I am unsure how it can be added manually... You can purchase blueCFD from blueCAPE (check price with them, but believe it is around Euro70). I will drop them an email to see if they might be willing to add swak4Foam to their blueCFD-SingleCore for the KVRC.
There are a number of alternatives:
- build a port of openFoam and swak4Foam for windows on your own - probably time consuming and frustrating experience, not for the faint hearted;
- install openFoam and swak4Foam on a Linux computer on the same network as your windows box and use right-click->analysis->remote->linux - it is probably the easiest way, but require two computers on the same network;
- use Amazon EC2 (right-click->analysis->remote->Amazon EC2). If you want to do this, let me know as I need your amazon user id to allow access to the image. It is reasonably experimental, and Amazon EC2 will charge you per CPU hour (not expensive though).
2. Individual components: Just place it the same way as you did with the car. You probably want to get the correct height above the ground to correctly account for ground effects, otherwise the position in the domain should not matter much. Just be aware that a component that is optimised by itself may behave differently when included with the car. To optimise run time, you can look at a number of aspects: do you need to run for 1000 iterations? Can you coarsen the mesh resolution?
For post-processing:
- Check the analysis output: right-click>Analysis>Output. Scroll down to the near the end and you should have the forces (in newton) and moment (in newton.meter to the 0,0,0 point). Both have two components: pressure induced forces/moment and viscous (molecular and turbulent) induced forces/moment.
- ParaView: right-click->Analysis>Paraview. In paraview:
+ Change time from 0 to the latest one (click on the up arrow);
+ Click on the apply button (on the left side of the screen);
+ Change the variable (may be called Solid Color) and may have to change the representation to "Surface" (it is a bit on the right of the variable in the toolbar) - on the left of the variable drop down, there are three buttons: rescale, edit scale and show legend (from right to left);
+ Just under the variable and representation in the toolbar, there are a few filters than can be applied: the section one is a good one.
+ Also, right-click (in the pipeline browser) on open and select the "xxxx.foam" file
+ In the object inspector: untick the internal mesh and tick the name containing car or car-body, then click apply. It should only show the car body. Check the pressure on the surface to see area of high and low pressure.
If all fails, have a check at the documentation...
The windtunnel links dont work so I have uploaded the files I have - http://www.mediafire.com/download/fgli3 ... tunnel.zip
astracrazy
astracrazy
31
good work richard
you don't need linux? i was always under the impression you did (or mac)
RicME85
52
Well...you do to run the swak4foam module but to get a basic figure, just like you can with Khamsin you just need to install the bluefoam singlecore file I posted above and then follow the commands Julien gave me in the Pastbin link.
