Mercedes AMG F1 W06
desl
desl
37
Re: Mercedes AMG F1 W06
Holm86
252
SiLo wrote:
That seems very... crude?
Ofc it's crude. They're just testing, to know what development path they should follow for the '16 car.
No need to refine this design now, with 2 races left, and having won both the constructors and drivers championship.
ajprice
ajprice
21
BBC commentary called it an S Duct, for what it's worth. 2016 development, will allow them to maintain the downforce level and use less wing.
theWPTformula
50
From what we've seen, it's no more than an S-duct-shaped vanity panel. The bulges by the pushrod pickups suggest they could be raising the heave spring height for 2016 - the front bulkhead height is fixed, so it can't be a chassis change.
I wonder why they covered Hamilton's with tape, though.
I don't really know why they want to test the vanity panel only; wouldn't the flow be different with a real S-duct when airflow gets pushed out of it, including over the bulge?
dren
227
It is a direct test comparison. Using it vs not using it. The aero profile is the same. I wouldn't compare a modified car running the S duct to the old unmodified car.
Honda!
SiLo
139
I would, that way its a direct comparison between having it and not having it. Rather that only sort of having it.
It's probably more because it looks like some chassis changes may have been made?
Felipe Baby!
dren
227
They probably plan to run the S duct on both cars and are testing its effectiveness. They likely had to make some internal changes to retrofit the duct, thus the bulge on the sides.
Honda!
dans79
267
based on the the shape of the panel and the location of the flow viz, I wonder if the s-duct isn't a dummy. Since Singapore and Lowe's comments made it clear they have a design deficiency, I could see them testing how rearranging the suspension would affect the aero.
202 105 104 9 9 7
ajprice
ajprice
21
If it sits on top of the body and it's up into the drivers eyeline, it might also be to check how much it got in the way of visibility. I think they did a similar thing in practice sessions as Brawn at the end of 2009, attaching raised humps above the front suspension points on the tub like the Red Bull RB5 had. The Mercedes W01 did then have a high nose, I never saw any photos of the Brawn with those bits on though :) .
Matt Somers
Matt Somers
179
ajprice wrote:If it sits on top of the body and it's up into the drivers eyeline, it might also be to check how much it got in the way of visibility. I think they did a similar thing in practice sessions as Brawn at the end of 2009, attaching raised humps above the front suspension points on the tub like the Red Bull RB5 had. The Mercedes W01 did then have a high nose, I never saw any photos of the Brawn with those bits on though :) .
From my original article http://www.somersf1.co.uk/2014/01/the-b ... gp001.html
Hail22
144
Friday:
Gilles Villeneuve
FrukostScones
163
after this pic,
I think it is S-duct and not visibility/monocoque testing for 2016... (AMUS is wrong I think)
Hole has been there at austrian test... and the last races anyone?
krisfx
krisfx
I wonder how many other updates they're testing while everyone gets busy on this S-Duct thing?
ripper
ripper
39
Piola says that Mercedes tried a new anterior suspension in FP1, it should be another test for next year.
