Ferrari F10
Re: Ferrari F10
TheRMVR wrote:
wesley123 wrote:It can surely be used to heat the rear tires, remember, Renault did same in 2008 in hte case of tire management so they could do longer runs. With the ban of fuel stops such an thing would be pretty logical to do, as you have to stop one time less for example or later due to the tire wich can do more laps. How you look at it, such an device can simply gain you alot of track ime, if you have to stop one time less it will save you like 20 seconds, and then i havent even talked about the laps after an stop, where these tires are on their optimum temps sooner then other teams.
Do you actually believe yourself?
Do you have an better explaination then? I know those gains i called are a bit over-the-top, but rfurther it is plausible, renault did the same in 2008
http://www.f1technical.net/development/206
Remember, in 2008 renault was very busy with tire management, they drove slower laps with the tires, so they lasted longer.
Earth
Re: Ferrari F10
Very nice onboard with Alonso in Fiorano :)
[youtube]http://www.youtube.com/watch?v=Kw5j_frD3Sg[/youtube]
autogyro
autogyro
Re: Ferrari F10
If that engine mapping system is not giving traction limiting then I am a monkeys Uncle.
aral
aral
26
Re: Ferrari F10
autogyro wrote:If that engine mapping system is not giving traction limiting then I am a monkeys Uncle.
Pity my name isn't Tarzan! Ferrari may have put a lower rev limiter, AND anyway, they would be quite in order to use traction control if they wanted, as there is no law against it other than in quali and race. However as ECU is provided by Mclaren and cannot be modified, I think that you are hearing things again!
madly
madly
Re: Ferrari F10
aral
aral
26
Re: Ferrari F10
madly wrote:Image
That rminds me of the time, in the 60's, when F1 cars were experimenting with biplane wings!
autogyro
autogyro
Re: Ferrari F10
I dont think so.
240
Re: Ferrari F10
n smikle wrote:i was thinking like this
well the upper ones must be fake or an illusion
5.6 Exhaust systems :
Engine exhaust systems may incorporate no more than two exits.
5.7 Variable geometry systems :
5.7.1 Variable geometry inlet systems are not permitted.
5.7.2 Variable geometry exhaust systems are not permitted.
mith
Re: Ferrari F10
Maybe that upper pipe (if it really is a pipe) is just cooling outlet?
korzeniow
korzeniow
Re: Ferrari F10
February 5, 2013
aral
aral
26
Re: Ferrari F10
I dont think so.
I DO think so! You have absolutely no valid reason to imply that Ferrari are running traction control. If you had, I am sure that FIA would love to hear from you!
sticky667
sticky667
Re: Ferrari F10
bill shoe
bill shoe
151
Re: Ferrari F10
Traction Control Issue- The engine has severe fluttering or misfiring sounds throughout the video. This is a clear contrast to the moments when the engine is pulling clean. Something is going on. The odd fluttering sound occurs right after gear changes.
The rules used to allow (and may still allow) 200 milliseconds for the computer to actively control the throttle after a gearchange. The was because the throttle needed to be actively controlled for the gearchange itself. If I remember correctly, Ferrari was the first to take advantage of this loophole to create 0.2 second bursts of traction control after gearchanges. The interesting thing is that the burst in the above video seems to be longer than 200 ms. Less than 1 second, but more than 200 ms. Perhaps after the 200 ms closed-loop traction control phase there is an open-loop transition phase back to the regular engine map, and this transition has the effect of making the fluttering noise longer than 200 ms.
I made a bit of a guess above, but anyone who wants to claim there is no traction control needs to come up with some kind of plausible explaination for the severe fluttering noise. A statement that Ferrari would not break the rules is not a functional explaination in this regard.
jason.parker.86
jason.parker.86
Re: Ferrari F10
wow them exhausts do look nice and shiney
240
Re: Ferrari F10
Now we've seen the pipes, lets see the new diffuser parts that the exhaust flows through.
