Mandrake wrote:Starting slower into the stint due to not getting the temperature up quickly enough will not lead to less tire wear. The tires will wear equally if not more during those stages. It's not like the tires can operate for 10 laps in the proper temperature window, they last 10 laps before the wear causes them to become much slower (hence we didn't see the dropoff in Monaco because the surface is very very smooth).
Ferrari can push longer with its tires as seen in Silverstone as well as in Germany and this is due to the fact that the car causes less wear on the tires!
I have not said that. Imagine the Trio has a window of 15 laps before they have to pit.
If Ferrari needs to laps for the tires to start working they will then pit on lap 17 compared to RBR or Mclaren who get the temp up on lap 1 and pit on lap 15.
Pierce89 wrote:only in lower temps do Ferrari have warm up problems. In Hungary NO ONE will warm up issues.
But, When you say all Ferrari does is move the window back two laps because they're slow to warm up, you're ignoring the fact that In those first two laps, they still have to set semi competitive laps. They're better tyre wear nearly jumped a faster Hami. Yes he got back by because Alonso tyres weren't ready yet, but without they're better wear rate Ferrari would never have had that chance at all.
This doesn´t make any sense. It doesn´t matter what temp it is, if the Ferrari is kinder on the tires it should be kinder everywhere.
There is no proof that Ferrari looks after it´s tires better then anyone else.
"semi competitive laps" I don´t even know what you mean by that.
They can´t get the temps up right away and have can´t do anything about it except running 1-2 laps until they are up to temperature.
Ferrari does not stop less then the two other teams.
Ferrari does not go longer on their stints by any margin like 5 laps.
Ferrari just has trouble getting the temps up.
You will see in Hungary that they will have less of a problem getting the temps up but you will also see that they will pit when everyone else do and have the same wear on the tires as the other in the Trio.
The truth will come out...
