Conrod
650
Re: Conrod
afaik
the tensile load will determine whether the small end eye can be designed for strength only ....
or whether stiffness (to avoid excessive contact loadings from pinch of the small end bearing) is the dominant design factor
Wright's Cyclone 18 c.1941 seems to have been a pioneer of H section rods
but maybe that was for the master rod only (and for master rod specific reasons)
or was it said that there some reason, from gas load distribution ?
strad
117
Re: Conrod
JEEEEEZ
Sorry guys I didn't look at the op date.
Never expected something like that to get bumped.
Sir Stirling Moss
Big Tea
99
Re: Conrod
I wish there was a thread that us plebs could ask this sort of engineering question of the more knowledgeable.
One of the main reasons I joined up her is the depth and strength of expertises and the (seeming) willingness to share.
Looking things up is fine if you have the depth of understanding to first know the right questions and then how to apply it.
There are also thongs that are race car specific and the answer is out there for road cars, but not really applicable to F1. For instance, the effect of gearing on fuel consumption in f1. Plenty on road cars, but the requirements are not the same.
63l8qrrfy6
63l8qrrfy6
368
Re: Conrod
Tommy Cookers wrote:
01 Apr 2018, 17:49
afaik
I agree, rod stiffness is very important, not only for small end and big end bearings but for the rod bolts too (the higher the bolt turret stiffness, the smaller the bolt load). It is one of the many reasons titanium rods are so hard to design right as its young's modulus is half that of steel.
I suppose that in the case of radial engines having a H section master rod makes for a tidier transition to the flange that holds the other rods ?
strad
117
Re: Conrod
Guess you could say I was conned. :roll:
Sir Stirling Moss
