hardingfv32 wrote:I have also seen research indicating the groove between the first and second compression ring grooves is for oil accumulation.
I have never seen actual tests verifying the effectiveness of this combustion gas accumulation zone. I have always been suspect of the theory.
Brian
Hopefully this will be of interest.
MIT have measured it working dynamically on an engine with highly instrumented pistons.
The RET (Race Engine Technology) article I posted, includes discussion of 2nd land grooves and how they work.
Mahle offers the following in a book on pistons and testing which they edited/co-published with MTZ (Motoren Technische Zeitschrift). "Brief periods of excessively high pressure between the first and second rings can cause the first piston ring to be forced away from the lower flank of the groove and thereby increase the lube oil consumption due to “reverse blowby” A change in volume between these two rings in the form of grooves chamfers or recesses can lead to faster and more immediate pressure equalization in the intermediate ring space"
Having seen various brands of piston-design snake-oil, I'm quite sceptical too but if RET, Mahle and MTZ say something is real and MIT have measured it and then I start to get convinced.
