Oil as fuel
zonk
zonk
69
Re: Oil as fuel
basti313
basti313
Re: Oil as fuel
hardingfv32 wrote:
23 Jun 2017, 18:15
We still do not know how these only vent/vapor system provide their benefit after the oil mist is in the intake system.
The oil mist is simply burned. The power in Q is limited by the limited fuel flow and additional stuff to burn means more power. This has nothing to do with lubrication.
hardingfv32 wrote:
23 Jun 2017, 18:15
If there was some kind of chemical not common to motor oil beginning used the FIA could have banned it and similar substances form the oil's composition.
I would simply increase the number of light hydrocarbons. They give a nice, well burning mist and are common in motor oil. Nothing to do against this.
The oil is anyway too complicated to control. The only way to control the abuse of the oil is to limit the oil consumption and to ban valves for crankcase breather abuse.
I think it is a very good rule change, but I do not understand why it is applied so late. A mid-season ban would have been easily doable.
Don`t russel the hamster!
ClarkBT11
Re: Oil as fuel
hardingfv32 wrote:
23 Jun 2017, 18:15
FIA has now stated explicitly that the use of chemicals in oil that could help improve combustion is not allowed.
Stargazer
Stargazer
Re: Oil as fuel
I just read a speculation on one of news sites that Ferrari uses 2 oil tanks filled with different oil. New oil tank is the one appeared in the floor of their 2017 car. And that the second tank has a special oil for the "oil burn" purpose. It's also stated that the latest 2017 regulation changes in this area were likely caused by Merc's request to FIA aimed at trying to slow down their rivals.
supermarine
supermarine
Re: Oil as fuel
Stargazer wrote:
24 Jun 2017, 00:21
I just watched Ted's Notebook and it sounds like Ferrari did indeed have a second tank with a different type of oil that would combust well.
hardingfv32
hardingfv32
Re: Oil as fuel
1) Name a chemical that would make a good fuel AND work as a lubricant? The latest lubricants have very high combustion temperatures. As an example they can make it through a CAT without lighting off.
2) Current lubricants provide a big reduction in friction…increase in power. It is going to take a lot of combustion energy to make-up for any loss friction reduction from an inferior lubricant. In other words this is a compromise.
3) Exactly how would you use a second tank of oil? Do you think they can just change oil formulations on the run?
Brian
Phil
66
Re: Oil as fuel
AMuS thinks this may explainwhy Ferrari was so quick on the straights in Canada and why here they seem to be lacking a bit...
#Team44 supporter
supermarine
supermarine
Re: Oil as fuel
hardingfv32 wrote:
25 Jun 2017, 08:30
Brian
I think the point is that the second tank contained 'lubricant' that was engineered to be useful as fuel. If you look at the wording of the technical clarification it seems pretty clear what it is designed to prohibit. These clarifications do not just come from nowhere, unless something was going on the FIA would not bother to do it.
Surely it should be possible to create a light lubricant that would evaporate upon introduction to the crankcase and flow out through the breather into the intake plenum. I was always sceptical about the value of oil burning with these very complicated lean burning TJI engines but if it is possible to use two different types of oil then it makes sense. The second oil tank is a de facto second fuel tank which is not subject to the fuel flow regs.
hardingfv32
hardingfv32
Re: Oil as fuel
Yes.. I agree
The viscosity of the oil is as low as it can possibly be to reduce friction and still maintain reliability. Compromising this for a short term power increase does not seem like a good compromise. It would be a net reduction of the power found under the curve for a session.
How about the second source of oil never actual mixes with the main oil supply. Say that the second source is used to cool the pistons. It could be very volatile and vaporize on contact with the piston. Never has the opportunity to mix with the regular lubricant supply. The vapor is exhausted into the intake. You could use a real fuel for this second source.
The calibration of such a system would seem very complicated.
Brian
NL_Fer
NL_Fer
82
Re: Oil as fuel
Remember the previous years where Mercedes would burn a big cloud of smoke, during or after then warmup lap.
Re: Oil as fuel
hardingfv32 wrote:
25 Jun 2017, 08:30
Brian
Maybe the oil works as a way to reduce knocking allowing more aggressive engine settings for longer. Or maybe the oil is burned in the exhaust for extra turbine power.
Re: Oil as fuel
NL_Fer wrote:
25 Jun 2017, 19:52
They still do, that Facts Only guy said it's because of a turbo seal issue.
ojlopez
ojlopez
Re: Oil as fuel
What if they have a 2 part oil, where the light burnable part separates from the thick lubricant part and floats on top of it so it can be easily scavenged and sent into combustion chamber?
irsq4
irsq4
-1
Re: Oil as fuel
godlameroso wrote:
26 Jun 2017, 13:42
NL_Fer wrote:
25 Jun 2017, 19:52
Smart way to send "combustion beneficial" oil ingredients into engine intake.
:mrgreen:
langwadt
langwadt
Re: Oil as fuel
ojlopez wrote:
26 Jun 2017, 16:16
or use the oil pump as centrifuge to separate them
