Oil as fuel
hardingfv32
32
Oil as fuel
The FIA seems to be taking a serious approach towards the consumption of oil. There seems to be a claim that it can be as a benefit during Qualifying.
ASSUMING this is true: How could the oil consumption of the current engines (and rules) be modified between qualifying and the start of the race?
Brian
nevill3
16
Contact:
Re: Oil as fuel
The current regulations allow different oil specifications to be used between qualifying and race, the rumour is that some teams are running a less robust specification that gives a performance boost during qualifying and then replace it with a more durable specification for the race. The proposal is to insist on only one specification per event per engine.
Re: Oil as fuel
Would it be a thicker oil for qualifying?
Hotter engine... more protection?
Or a thinner oil?
henry
324
Re: Oil as fuel
PlatinumZealot wrote: ↑
27 Apr 2017, 17:50
Or a thinner oil?
I think the suggestion is that the oil used for qualifying substitutes ingredients that lubricate with ingredients that burn as fuel or act as catalysts to improve the burning of the fuel itself.
Phil
66
Contact:
Re: Oil as fuel
As far as i understand, didnt the FIA already start to monitor the amount of oil being used? If yes, that could perhaps explain why Mercedes (if they are in fact using this) can only use it more effectively during qualifying and not during the race?
Not for nothing, Rosberg's Championship is the only thing that lends credibility to Hamilton's recent success. Otherwise, he'd just be the guy who's had the best car. β€” bhall II
#Team44 supporter
dren
226
Re: Oil as fuel
I was under the assumption that Mercedes had access to the Q3 mode during the race, so perhaps this isn't the 'special sauce' that Mercedes uses to turn up their PU in Q3.
Honda!
Re: Oil as fuel
henry wrote: ↑
27 Apr 2017, 17:56
27 Apr 2017, 17:50
Or a thinner oil?
Yes but apart from using the oil to cheat the fuel regs... I was wondering if you had to use an oil grade only for qualifying what viscosity would be prefered.
BrunoH
Re: Oil as fuel
i bet its a thinner oil, to give some extra performance on qualy, its only a few laps so even if wear is higher its not goint to be anything critical...
simplefan
Re: Oil as fuel
I've heard a lot about burning oil for boosted performance lately but wasn't the same being done during the last V8 era? I seem to remember lubricant suppliers boasting of hp gains on the frozen spec engines.
J.A.W.
109
Re: Oil as fuel
27 Apr 2017, 17:50
Or a thinner oil?
AFAIR, back in a less tightly regulated NASCAR era, specific ultra-low friction Q-engines were used,
inc' tribological advantages via 'watery' viscosity/high lubricity short-life oil..
Today, although oddly oil is - one area in F1 which is not so rules constrained, engine life is,
& oil formulation types affecting engine power vs durability must be a calculated risk..
FW17
168
Re: Oil as fuel
Rule changes planned for next year include a new regulation that teams must supply the measurement of the oil level of its main tank to the FIA at all times of the event, that active control valves between the power unit and engine air intake be banned
-- FIA Technical Directive
563
Re: Oil as fuel
I am amazed that such valves would not be currently prohibited.
621
Re: Oil as fuel
[quote=FW17]
[quote]Rule changes planned for next year include a new regulation that teams must supply the measurement of the oil level of its main tank to the FIA at all times of the event, [b]that active control valves between the power unit and engine air intake be banned[/b] [/quote]
[/quote]
I thank you ....
(yes, I do feel vindicated)
a victory against standard-issue technical/scientific fraud as widely encouraged and/or mandated by law in our 21 st century
basti313
25
Re: Oil as fuel
hardingfv32 wrote: ↑
27 Apr 2017, 17:32
Brian
Well, these are no claims or assumptions. It is quite clear that teams are burning oil for performance, that is why they even changed the rules to avoid this next year.
Also the rule change makes quite clear how they do it: They simply feed oil mist through the crankcase breather into the intake. With a simple valve and a bypass line round the oil separator you can easily control the amount. With nice oil additives you can have a very well burning oil mist...
With a capillary you could even feed liquid oil, but I am not sure if this would be the best idea.
nevill3 wrote: ↑
27 Apr 2017, 17:42
The discussions about Hamilton's engine blow up last year were quite clear, that they use only one oil spec. And they changed it round the event to a thinner one and went back to thick oil afterwards. They are quite close on the limit with the oil, I do not see room for playing games with Q-oil.
Don`t russel the hamster!
hardingfv32
32
Re: Oil as fuel
We still do not know how these only vent/vapor system provide their benefit after the oil mist is in the intake system.
If there was some kind of chemical not common to motor oil beginning used the FIA could have banned it and similar substances form the oil's composition.
Would anything in the intake tract require more lubrication during a qualifying engine mode setting?
Brian
