And they'll need it, because that McLaren is going to get real quick real fast.
Direct quote from Seb saying they didnt take the unit out, must be to do with the mandatory weight distribution, so no benefit in terms of CoG. But as Martin Brundle said, the KERS regeneration requires the break balance to be shifted forward so could have made the car much more drivable.Formula1.com wrote:Q: Lewis has KERS on his car. You don’t have KERS on you car?
SV: We do have KERS on the car, but we didn’t use it. It is not that we take it down and then are lighter than the rest. That was in 2009 when you could take it down and play around with the weight. And I was wondering why nothing was happening… (laughs) But let’s be serious again - we have to get it working for Malaysia.
Could be but it's a myth that people who should know better have been perpetuating, e.g. the BBC commentators.richard_leeds wrote:myurr - KERS can be used from the start line.
tumbarello - The 100kph limit is an urban myth. The teams can use KERS from stationary if they want. However there was a theory discussed in 2009 that the most effective use of energy is to use it once they have gained traction. Using KERS in a standing start would increase wheel spin.
It helps the hoon-factor, of courseGiblet wrote:My understanding which might be wrong or right is that the cars are traction limited until that speed anyways so there is no need to use it below 100 because they can't put the power to the ground.
Makes sense if you are feathering the throttle to keep the wheels from spinning, how will putting an extra 80hp help?
i agree, if you are still not at (or near) WOT at that point, there is no point wasting KERS, to add 80hp, when you can probably just add that with your right foot, and probably much more accurately,Giblet wrote:My understanding which might be wrong or right is that the cars are traction limited until that speed anyways so there is no need to use it below 100 because they can't put the power to the ground.
Indeed, KERS is on/off, there's no feathering at all.she_spools_180 wrote:just add that with your right foot, a probably much more accurately,
