Mercedes AMG F1 W04
mep
29
Re: Mercedes AMG F1 W04
Regarding the FRIC system.
I noticed that the Mercedes lifted the inside front wheel from the ground a couple of times during the Malaysia race.
Could be related to a very soft roll stiffness.
Ferraripilot
21
mep wrote:Regarding the FRIC system.
That could be the case, or as Dr. Helmut Marko stated today it could be a very soft setup due to tires. Helmut stated these tires seem to peel off in chunks the more downforce put on them. Mercedes softer setup could be advantageous to these tires as it removes some of that tire load which destroys them so easily.
siskue2005
siskue2005
70
shouldnt a softer suspension cause more tyre wear?
thats what we experience on sim racing in rfactor and iracing
siskue2005 wrote:shouldnt a softer suspension cause more tyre wear?
Depends, softer relative to the field might still be stiff enough to prevent the kind of weight transfer that would cause uneven thermal stress on the tires. Part of that depends on the stiffness of the chassis and suspension geometry etc.
Nando
Nando
Bredd wrote:Merc had good pace today and good traction and speed in the corners yet they seem to lack a little top speed. When hamilton did have his drs open on vettel he just didn't seem to get anywhere. Maybe get the passive drs working?
Yea i checked the time-delta and it looked like he actually lost time even though he was on the DRS.
Like a tenth or so.
Owen.C93
Owen.C93
191
Depends on if you're sliding around or not. You can stop some oversteer and wheel spin by softening up the rear and even take some flex out of the tyre to reduce temps.
khaliweed
khaliweed
Are they having different side vents next to drivers head?
GrizzleBoy
GrizzleBoy
Indeed they are. Interesting.
What could be different enough about the cars to warrant different vents?
Also note the angle of both front wings from front to rear :)
Nando
Nando
Nice find!
pmneo
pmneo
Nico's car also have a camera housing an the right side ...
And the two dark dots above the exhaust has different distances at both cars ...
Behind the vents of lewis car is another dark dot.
gray41
Has there been any quotes about a Chinese GP update?
What areas are we likely to seem improved?
Lewis Hamilton #44
2016
Poles: *****
Wins: ***
diego.liv
diego.liv
GrizzleBoy wrote:Indeed they are. Interesting.
Imo, front wings have the same angle, a bit of photo-prospective.
About the vents, were Mercedes trying a bit different cinfigurations between the cars to collect more data? Nico and Lewis pushed both, it didn't seem like one pushed more. A more aggressive config for Lewis with more holes for ventilation?
Cocles
I think Hamilton's DRS is open. This was probably taken as they were drafting each other, since Hamilton is retaking the lead, that would make it the second DRS zone.
outer_bongolia
Good eye. Both wings seem to be tilting backwards.
Skeptical scrutiny is the means, in both science and religion, by which deep thoughts can be winnowed from deep nonsense.
Carl Sagan
Gridlock
42
Image Image
Almost definitely, with this and the Red Bull Red Dots, lateral rotation is still a performance differentiator then.
#58
