f1motta
f1motta
64
Changes made by Honda in their combustion chamber (on the right):
cheeRS
cheeRS
f1motta wrote:
05 Apr 2021, 12:46
Cylinder plating - Honda's secret weapon. Amazing job did in small workshop in Kumamoto factory unlocked their full potential.
https://i.imgur.com/YMy2cDf.jpg
Where could watch said video?
Human history is the long terrible story of man trying to find something other than God which will make him happy.
f1motta
f1motta
64
New engine head cover (more compact, smaller & lighter) - different camshaft position:
f1motta
f1motta
64
cheeRS wrote:
05 Apr 2021, 19:53
f1motta wrote:
05 Apr 2021, 12:46
NHK on demand platform.
subcritical71
90
f1motta wrote:
05 Apr 2021, 20:06
cheeRS wrote:
05 Apr 2021, 19:53
f1motta wrote:
05 Apr 2021, 12:46
hUirEYExbN
These were already posted and have been talked about for the last 3 pages.
viewtopic.php?p=962727#p962727
ispano6
164
hUirEYExbN wrote:
05 Apr 2021, 22:19
It's important to note that it is not the actual engine head cover of the RA621H. It is in fact a prototype and sample head cover meant for the purposes of showing the difference in size. The actual head cover is different and hasn't been revealed.
f1motta
f1motta
64
Sorry guys, I missed that page. Here are my notes after watching this video. I hope this time you will find something interesting:
1. The elements that limited Honda were cylinders and the lack of resistance to the forces acting on them - temperature and friction.
2. The experience of Honda Motor engineers was used, who developed their own technology of strengthening the cylinder surface by creating or applying an appropriate coating. For the new power unit, they developed a recipe that made the cylinders five to ten times more resistant than that used in Honda motorcycles.
According to the information provided in the video, they checked the strength of the new cylinder shell in Abu Dhabi 2020, allowing the use of full power. The test was passed, so it was possible to think about solutions to improve performance.
3. Honda has been analyzing the old unit for months and has been looking for areas to improve performance. Japanese specialists quickly concluded that a complete reconstruction was necessary. Having, at least theoretically, certain that the new coating would protect the cylinder from excessive wear, they reached for a new shape of the combustion chamber allowing for a greater degree of compression. This has been achieved by reducing the angle at which the valves are positioned. This operation resulted in the camshafts getting closer to each other. This, in turn, allowed for a more compact design.
4. The increase in unit efficiency, however, had a side effect - the amount of "lost" energy that went to the exhaust system and then powered the turbine decreased. Here again the HondaJet specialists came to the rescue. A redesign of the blade shape allowed the MGU-H system to perform efficiently despite the lower exhaust energy.
5. More attention in this video has been given to Toro Rosso/AlphaTauri than to Red Bull.
--- Last two are from f1.com ---
6. The use of new materials for the construction of the engine block allowed to reduce the distance between the cylinders (bore pitch). This was another area that allowed the engine size to be significantly reduced and the center of mass to be lowered.
7. Lowering the center of mass and the size of the unit allowed Alpha Tauri and Red Bull (especially them) to gain further advantages on the aerodynamic side.
Owen.C93
Owen.C93
177
KAIZEN wrote:
03 Apr 2021, 23:13
By regulation, you cannot change the mounting position of PU, right?
I tried to match only the two bolt positions.
Yeah the Y-Z mounting positions are fixed. So have they offset the height of the 2 cams as well?
etusch
131
f1motta wrote:
06 Apr 2021, 07:47
Thank you very much man.
By the way, that win in Abu Dhabi was not just Merso's engine power dicrease as some guys said who are locked their head into "mercedes is unbeatable and will stay so" dungeon.
etusch
131
f1motta wrote:
05 Apr 2021, 20:04
https://pbs.twimg.com/media/EyOpL-jXIAA ... name=large
At this 3rd picture, it is more obvious that they are talking about really big improvement of compactness of İCE. Wonderfull. Thank you @f1motta.
scheffers
scheffers
henry
324
subcritical71 wrote:
05 Apr 2021, 14:00
henry wrote:
05 Apr 2021, 12:39
The previous lap times, tLastLap, are very long and the State of Charge, SOC, very high (99%) so maybe this is a warm up or installation lap.
What do you make of the SOC bar graph? Units are SOC and has some delimiters at what looks like 0, 20, 95 and 100. Both sides show the SOC as >99% but the bar itself is around 90%. I thought about SOC of battery vs SOC range allowed by the rules but then the highlighted part of the chart wouldn't go to 0 unless its a limitation of their software.
On reflection I think the numbers are snapshots of lap number 2. So possibly the SOC at the end of the lap. The bar graph may well be real time data. It doesn’t look like they are using much SOC so I doubt this is a performance lap.
Thinking about the data I would expect most of the numbers to be snapshots at some regular the time intervals, many of the numbers would be varying too quickly otherwise. The graphs show the trends and the numbers a snapshot to check specifics. But that’s only a guess.
Could very well be from pre season testing 2020 as there was no running at 13:35 at last year's Spanish GP.
If this is local time.
650
f1motta wrote:
06 Apr 2021, 07:47
.... a greater degree of compression.... achieved by reducing the angle at which the valves are positioned.....
though of course reducing the VIA reduces the space available for the valves ie reduces the valve sizes
