Mclaren MP4-30 Honda
mikeerfol
68
Re: Mclaren MP4-30 Honda
This was posted by the user muramasa over at autosport.
http://as-web.jp/photonews/info.php?c_id=1&no=76347
Also:
dren
228
I can't stand that second swoosh on the nose.
Honda!
Lucky
Lucky
157
The Inlet Plenum seems to be made aut of Carbon now.
Lucky
Lucky
157
So the Livery change extends even on the Internals.... :D
3jawchuck
3jawchuck
37
I think a change to the inlet plenum comes at the cost of a token? I don't know, but I doubt a material change would be free.
GPR-A duplicate2
64
Is that some kind of fibre coating on top of the plenum, instead of plenum itself being made up of fibre element? A metallic object provides far more air tightened sealing than a fibre one, where there is some amount of elasticity in its nature.
Silent Storm
Silent Storm
130
Some manufacturers have started using carbon fibre intake manifold and airbox to save weight in road cars. Plastic intake manifold is used in road cars to save weight and reduce cost.
Same reason can be applied here.
I see no reason why carbon fibre cannot provide a air tight seal than a aluminium one.
GPR-A duplicate2
64
You are right, as far as the road cars are concerned. But in these F1 cars, heat inside would play a big part in influencing the elasticity of the fibre.
The plenum shape didn't change so can Honda defend the change as one that doesn't increase performance of the engine? (Car performance improves though!! lighter weight!)
Silent Storm
Silent Storm
130
Carbon fibre has better high temperature tolerance than other materials.
That is why they changed it.
I don't think they gained 2 tenths from that so no need to defend!!
taperoo2k
taperoo2k
GPR-A wrote:
Silent Storm wrote:
GPR-A wrote: I see no reason why carbon fibre cannot provide a air tight seal than a aluminium one.
Depends on how the carbon fibre has been structured in the manufacturing process. For all we know there could be a thin layer of aluminium or other material to act as an air seal (no idea if that would be allowed in terms of the regulations). Also heat dissipation in this case might be a help more than a hindrance given where this part is located in the car.
