Ferrari F10
240
Re: Ferrari F10
why am i seeing #8 used for ita, sing, jap, and korea? #-o
Ok, the bahrain engine is gone to engine heaven. So in the case he does not want to use a 9th engine nor the 8th (which i'm assuming he used 4 times from the chart).
Will he have to use #2 then #3 in that order for the last 2, or he's free to use any of the fresher engines.
Ok lets make this simple.
What options does Alonso have for the last 2 races. A new one sounds like a good option.
Heidfeld is complaining about the drop in power of the sauber engine.
http://formula-one.speedtv.com/article/ ... k-heidfeld
Maybe sauber has the crappy ferrari engines, but alonso's car should have similar problems.
forty-two
Re: Ferrari F10
Hmm, interesting article that Ringo, thanks for posting.
I personally wonder if the reason heidfeld is blaming the "loss of power" due to "older engines" is because in order to make them last longer, the team are telling him to turn the wick down a bit.
Thoughts?
imightbewrong
imightbewrong
Re: Ferrari F10
ringo wrote:why am i seeing #8 used for ita, sing, jap, and korea? #-o
It just shows how many engines were used to that point. So engine 8 was first used at Monza, but it wasn't actually used in consequent races.
They have been running most engines for three races, so I don't understand why there should be a problem to run the Monza engine for two more races (three in total).
Gerhard Berger
Gerhard Berger
-1
Re: Ferrari F10
Viva F1 only shows when a new engine was introduced. It doesn't show what engine was used at what race.
#8 was introduced at Monza, but hasn't been used since then. It will definititely be used for the last 2 races.
#3 blew up in Malaysia, #2 had a fault in it which they were unable to fix due to the seals put on the engine after they have completed 1 race.
If in doubt, look at the list i posted on the previous page, it shows what engine was used at what races.
240
Re: Ferrari F10
Oh i see.
I guess the trick is which ones to use in free practice 1 & 2, and which one for practice 3. We have no idea how ferrari have been using these units in the different practice sessions.
If an engine fails in practice 3, that's a penalty is it?
Ferrari are managing quite well, as if they never had 2 engine failures.
Mr Alcatraz
-27
Re: Ferrari F10
forty-two wrote:Hmm, interesting article that Ringo, thanks for posting.
Thoughts?
Nick's Sauber (actualy Pedro's) broke into engine #9 at Spa that was 5 races ago so what he is saying is he has been runing races (probably the last two) with well worn engines that are tired but have not expired . I guess they are going to try to make it to the end without using #10.
Unless it's a money issue they should let the guy have a new engine. It's not like they have a chance to overtake Williams in the WCC
So yes I suspect he is running races with the wick turned down more than they would like to.
Those who believe in telekinetics raise my hand
kalinka
kalinka
Re: Ferrari F10
Because the Monza engine is the least good to be used in 3 races. Monza puts the highest stress on engines, and Alonso run it 110% I believe to win in Monza. Let's say, the engine used in Monza has the highest probability ( for any team ) to blew during other (2) races.
Agenda_Is_Incorrect
Agenda_Is_Incorrect
-5
Re: Ferrari F10
kalinka, don't forget that Brazil is said to put less stress on the engines because of the higher altitude :wink:. If that's true it was a smart move from Ferrari, as it will have a regular engine for the last two races.
I've been censored by a moderation team that rather see people dying and being shot at terrorist attacks than allowing people to speak the truth. That's racist apparently.
God made Trump win for a reason.
Mr Alcatraz
-27
Re: Ferrari F10
Agenda_Is_Incorrect wrote:kalinka, don't forget that Brazil is said to put less stress on the engines because of the higher altitude :wink:. If that's true it was a smart move from Ferrari, as it will have a regular engine for the last two races.
Fred knows what is jake.
He will know how to get the max out of that rig.
Underestimate him at your own peril.
His judgement in the poceeding mortal combat will be most swift and quite final.
This guy Fred;
He is a rather clever fellow :-"
Gerhard Berger
Gerhard Berger
-1
Re: Ferrari F10
This is true, but you also have to take into account that Interlagos is easier on the engines because of the altitude, whilst Abu Dhabi is not much of an engine killer.
Francesc
Francesc
51
Re: Ferrari F10
New F-duct to the main plane
type056
type056
Re: Ferrari F10
Francesc wrote:New F-duct to the main plane
[img]http://f.i.uol.com.br/fotografia/2010/1 ... 1.jpeg[img]
it seem there are two different new nose cones.
Re: Ferrari F10
the angle is playing tricks on you mate, Nose cones are homologated and thus cant be changed in season
Re: Ferrari F10
No, he is saying that Francesc did not post pictures of any rear wing as said, Francesc only posted a picture of two front wings.
raymondu999
Re: Ferrari F10
wesley123 wrote:the angle is playing tricks on you mate, Nose cones are homologated and thus cant be changed in season
The crash structure is homologated. Whether or not the nose cone is a direct crash structure or there is an underlying crash structure is a different matter
失败者找理由,成功者找方法
