Mercedes AMG F1 W09 EQ Power+
krizalid1001
krizalid1001
Re: Mercedes AMG F1 W09 EQ Power+
And something new with the front brakes
Via AMuS
NoDivergence
NoDivergence
52
paddyf1 wrote:
01 Mar 2018, 18:49
Morteza wrote:
01 Mar 2018, 18:34
Flow-viz testing on the rear wing (photo is from Tuesday)
https://pbs.twimg.com/media/DXN1SEMXkAYMi6i.png:large
Via @RacecarEngineer
flow attachment across both rear wing elements
Not only that. That flow field looks gorgeous. Almost no spanwise flow
paddyf1
paddyf1
NoDivergence wrote:
01 Mar 2018, 20:37
paddyf1 wrote:
01 Mar 2018, 18:49
Morteza wrote:
01 Mar 2018, 18:34
As a ferrari fan i don't like seeing this....i dont think i`ve ever seen as good at that..
hurril
hurril
NoDivergence wrote:
01 Mar 2018, 20:37
paddyf1 wrote:
01 Mar 2018, 18:49
Morteza wrote:
01 Mar 2018, 18:34
ELI5 please?
k.ko100v
k.ko100v
19
A little bit more from today
Regards,
Krasen
MVRC - KostovRacing
atanatizante
134
In this area both lower wishbones and the drive shaft acts together like a lower beam wing?
Jesus
F1Krof
96
Williams' got the same solution. However, interesting to see Merc not going for that 'Crab' rear-upper wish-bone solution like McLaren, Williams, Renault and some other teams do. They're basically clearing that area for cleaner downwash towards the difuser.
Wroom wroom
Phlumbert
Phlumbert
krizalid1001 wrote:
01 Mar 2018, 14:23
Morteza wrote:
01 Mar 2018, 14:16
Via @AlbertFabrega
Seems like a bite of burning marks
Looks like a vent of some sort?
zibby43
zibby43
Phlumbert wrote:
02 Mar 2018, 03:08
krizalid1001 wrote:
01 Mar 2018, 14:23
Morteza wrote:
01 Mar 2018, 14:16
https://pbs.twimg.com/media/DXM78ZKX4AMfzzg.jpg
Via @AlbertFabrega
Yes, I've seen a few additional photos that capture that same area and it definitely appears to be a vent of some sort.
Sierra117
I carried out a rather crude and probably redundant calculation once I found an opportunity.
Assuming the intermediate tyres have a 670mm diameter, I took the front tyre, placed a rectangle to fit its dimensions, halved it to 335 (for a bit more control I guess) and then just queued them side by side until what I could make out of the centre of the rear tyre. Got 3685mm. Of course, there's some margin for error considering the car is parked at a slight angle, there's the parallax effect combined with the rear tyre's visibility or lack thereof.
NIKI LAUDANZ SolidarityCubolligraphy | Instagram | Facebook
#Aerogorn & #Flowramir
RZS10
359
use this link for the image https://image.prntscr.com/image/k-5SGOC ... puwiAw.png
(found by F12, ctrl+F, search for png)
i just used the same method of measuring the scale on the yellow markings several times (between -30 to 30; -30 to 10; -10 to 0; 0 to 10) and determining the avg. cm/pixel which gives me ~380cm between the middle of the yellow markings
with your 368.5 and my 380 the truth probably lies somewhere in between (like the old calculated 376 ....hehe ... it also shows how a slight increase in pic resolution can change the result .. -6 to 8 cm ... the 376 are just 10 pixels away)
Sierra117
RZS10 wrote:
02 Mar 2018, 14:05
with your 368.5 and my 380 the truth probably lies somewhere in between (like the old calculated 376 ....hehe)
Ah yes! I had this issue earlier with prntscr several months back and I had forgotten the solution, many thanks for this :)
Indeed, at first I thought after your pixel approximation method there would be no point in doing it once more, but as Dumbledore once said, "curiosity is not a sin, Harry ... " :D
Morteza wrote:
01 Mar 2018, 18:34
Interesting how there is a little flow-viz on the underside of the diffuser(outside corner of the horizontal surface) even though the flow-viz is applied to the top surface.
simieski
simieski
wesley123 wrote:
02 Mar 2018, 14:58
Morteza wrote:
01 Mar 2018, 18:34
Right hand side? Looks like a thickish line where it has dripped down onto it and then been blown backwards.
Thank you to God for making me an Atheist - Ricky Gervais.
simieski wrote:
02 Mar 2018, 18:37
wesley123 wrote:
02 Mar 2018, 14:58
Morteza wrote:
01 Mar 2018, 18:34
Left hand side.Where the gurney bends downwards. The horizontal surface of the diffuser has a bit of flow-viz on the outside corner
