Ferrari SF-25
FittingMechanics
FittingMechanics
16
Re: Ferrari SF-25
sucof wrote:
16 May 2025, 12:27
Thanks, I appreciate your reply.
Then this makes this reporting method quite useless.
FIA, F1 should change a lot in this regard, show, explain the technology to all the viewers, if it is more than half of the sport... they are basically ignoring it.
They added this so the journalists can have an easier time keeping track and writing technical articles. I think it is a net positive and I am fine with not everything being disclosed.
FDD
FDD
83
Re: Ferrari SF-25
ringo wrote:
15 May 2025, 17:46
Farnborough wrote:
15 May 2025, 12:09
Vanja #66 wrote:
15 May 2025, 11:41
Is this part about my original post as well?
I think it would be fair to remove the downvote to ringo, he simply posted RB photos to make his point in agreement. I actaully used one of those photos on X to make the same point too
No absolutely nothing about your part at all.
Ringo contributing that push instead of pull completely misses the point and illustration of lacking what is in this Ferrari design. I think its fair to vote on that basis.
Nah, my name is just a lightning rod to you and some others. Ringo = Bad guy! :lol:
I think you missed the point. I do not have a cross section of the ground effect Ferrari gearbox, so I used redbull to demonstrate how much more room exists in the upper region of the geabox. Let the red mist settle man.
I could have used any gearbox in fact to show a trapezium with a narrower base.
Mercedes made the same transition to pushrod, for various reasons, both aero and mechanical.
Ultimately Ferrari could have avoided a development conundrum if they had more space to work with. Now they have to consider priorities for the small volume. I would not be surprised if they extended the gearbox longitudinally to find more space, then incorporate new control arms to maintain their wheel base.
As for torsion.. I can assure you Ferrari do not have any torsional problems with their suspension structure.
Let's use the Redbull case again. What we see is a titanium reinforced carbon fiber subframe. Most teams are probably doing this.. and that thing is not going to twist because of wheel loads.
Absolutely right about the torsion.
If they have torsion problem with the suspension structure in which gearbox take a crucial role, they can simply not change the gears with torsion deformations since the tolerance in the gearbox its self is practically non existing.
Farnborough
Farnborough
125
Re: Ferrari SF-25
You're clearly, FDD, not aware then that the rear structure is NOT the gearbox on these cars ?
The "gearbox" containing gears, transmission, diff etc is a discreet singular enclosed item and separate from the rear structure we've been discussing on this thread.
FDD
FDD
83
Re: Ferrari SF-25
Farnborough wrote:
16 May 2025, 17:12
...but it is part of the rear compartment, not possible to be absolutely independent, so "distortion" must affect it.
240
Re: Ferrari SF-25
Farnborough wrote:
16 May 2025, 17:12
I think you have a misintepretation of the structure. Maybe you should share some images to support what you are saying.
The suspension is a rigid structure on it's own. It is fixed to the gearbox. If you want to call it a singular enclosed item, it does not change the fact that both are rigidly fixed together. There's also the rear crash structure. That is also rigidly fixed. It may be via bolts or studs. Removable and modular yes, but still fixed.
What is definitenly not this case is some kind of flimsy skin or casing holding all the pickup points and that thin casing is slid over and warping around the gearbox when loads are applied.
They're all rigidly connected and torqued down. And in the Red Bull example, the extent of that whole titanium subframe bonded in carbon pretty much will not twist. The suspension loads are coming through the rockers mounted on that sub frame. This subframe has the engine pick up points right on the outside too. So i am not sure where or how this god-like twisting is going to happen that a team is going to grossly miscalculate or not account for.
Farnborough
Farnborough
125
Re: Ferrari SF-25
I'll put the question .... have either of you seen a contemporary design in reality, of these gearbox ? ? ?
I've described it, accurately, again you demand "evidence" when its clear to me you really don't know whats in these things.
I was specifically forbidden from using any camera etc when viewing those components for real. No images will be forwarded to support. I can describe what I saw in front of me, you don't appear to be similarly intimate with detail.
Its amusing that you're so sure of structural performance .... without offering any "evidence" or knowledge of even the area that you proclaim as being beyond torsional absolute performance.
Every structure possess a level at which it performed in design and how the build made successful use or failure of that attribute. Your ignorance of specifics illustrate particular lack of knowledge for this area.
Farnborough
Farnborough
125
Re: Ferrari SF-25
ringo wrote:
17 May 2025, 02:57
Farnborough wrote:
16 May 2025, 17:12
This statement Illustrates clearly that you really don't have any real experience of current practice, you're offering lack of that knowledge as proof ? Really, this "evidence" of yours isn't sufficient for you to judge what really is in those design.
Farnborough
Farnborough
125
Re: Ferrari SF-25
This "What is definitenly not this case is some kind of flimsy skin or casing holding all the pickup points and that thin casing is slid over and warping around the gearbox when loads are applied." presented in some considerable false gravity as to it's provenance, could not be more diametrically opposed in reality to existing and contemporary designs used in F1.
You've used the word "flimsy" not me, is that method to denigrate the technical overview I've given ?
Each and every component on these design is pared down to the minimum for ability to meet the performance envelope expected of it. Each addition mass, space, overcapacity is to the negative, with everything examined through their process to meet the absolute "cross section" of performance against waste, cut back to the absolute pinnacle AS THEY VIEW IT in deliverance of the task.
Whether the design criteria is sufficient, or the manufacturing process and materials are able to meet that level, without excessive capacity is exactly the task faced by the team.
Since gearbox lifing and penalties were established, most/all of the teams moved to "exoskeleton" type rear structure ..... which can be changed in design and for accident damage eventuality .... without incurring gearbox penalties to facilitate this practice.
If you've no knowledge of this (clearly you've not as the quote above illustrates) brings the question of, are you fit to offer judgement in this discussion while lacking basic insight as to the design ?
240
Re: Ferrari SF-25
Farnborough wrote:
17 May 2025, 10:16
ringo wrote:
17 May 2025, 02:57
Farnborough wrote:
16 May 2025, 17:12
You do not know what you are talking about. I respectfully disagree with you and will not respond to anymore on this subject.
vorticism
vorticism
356
Re: Ferrari SF-25
📸 Sutton
FDD
FDD
83
Re: Ferrari SF-25
ringo wrote:
17 May 2025, 16:19
Farnborough wrote:
17 May 2025, 10:16
ringo wrote:
17 May 2025, 02:57
Some engineers from the highest categories of autosport describe essentially what you said.
One of them (expert for materials) is working for F1 indirectly.
Yes, You do not have to respond on this :wink:
Farnborough
Farnborough
125
Re: Ferrari SF-25
Images and discussion pertinent to SF25 @ approx 2:55 timeline.
Farnborough
Farnborough
125
Re: Ferrari SF-25
This is NOT from ferrari, but is pertinent to discussion of structural design and implementation within these current cars.
Particular points of comparison show at 2:59 .... 3:59 ..... 4:40 in concise illustration of gearbox components (cassette, gear case, outer casing with suspension pickup incorporated) to give overall appreciation of the complexity within these design elements and how they are arranged.
Real "evidence" in other words, from a source that's traceable and informed by a visit to team workshops. Its lucid appreciation of what's inside these component.
Logical separation of gearbox and suspension pickup allowing crash damage to have parts replaced without incurring known penalties for gearbox lifing.
Apologies its not Ferrari, but it is one of the best available public overview of contemporary design practice to see into these parts that teams will usually have hidden from journalist sight.
It appears common knowledge in coverage now to accept that Ferrari are working to replace elements of this in their own design.
Re: Ferrari SF-25
I'm affraid you misunderstood the video mate. Outer casing is the only gearbox casing, it's explained starting from 1:00 in that video. What you see on testing photos are testing cases used for dynamic tests, so obviously they don't have the pickup points and other stuff. Rear crash structure goes behind and is bolted onto GB casing
If there was a separate mechanical casing for gearbox unit and another for suspension pickup points, it would defeat the purpose of using engine and gearbox as stressed members in the first place. Engine was first used as stressed member more than 70 years ago
Brahmal
Brahmal
27
Re: Ferrari SF-25
Pretty sure that Sauber runs Ferrari-made transmission mechanicals inside their own custom casing, which allows them to use a different suspension set up.
