2023 Aston Martin | Aramco | Cognizant F1 Team
KimiRai
KimiRai
301
Re: 2023 Aston Martin | Aramco | Cognizant F1 Team
NAPI10 wrote:
09 Jul 2023, 22:38
What exactly is 'Car Charterisitic' & how it carries over seasons even after the change to the overall design philosophy?
Organic will give you a more detailed answer than I can.
NAPI10 wrote:
09 Jul 2023, 22:38
KimiRai wrote:
09 Jul 2023, 22:16
09 Jul 2023, 22:14
Yes just going by that trend I now expect a bad race for them there :D those car characteristics do tend to carry between years, especially particular outlier tracks for a car's performance
Monza will be an absolute disaster then if the trend is maintained... hopefully it's not to that point.
Things like..
Putting too much energy into the tyres eg Haas, or being gentle on the tyres eg RB
Having a slippery car eg Williams
Having good low speed performance eg Aston martin
Having poor handling behaviour in certain corner types eg McLaren in slow corners
Many of the above characteristics have carried over multiple seasons, some even from before 2022 into the current era. McLaren have had this strange handling characteristic according to Lando for years - maybe something to do with their wind tunnel not being able to simulate yaw. Williams is another, being slippery for many years now.
Mercedes have always been fast at Barcelona. Doesn't seem to matter how they design their car but it always runs well there. And they don't tend to have a car that likes Monaco, regardless of the car philosophy. That likely comes down to a combination of car characteristics that derives from broad decisions made early in the design process - in previous era that might be something like wheelbase
Spoutnik
Spoutnik
09 Jul 2023, 22:45
NAPI10 wrote:
09 Jul 2023, 22:38
KimiRai wrote:
09 Jul 2023, 22:16
Things like..
I agree with you but there's some shift sometimes :
- RB went from being draggy, low top speed (Vettel years/high rake RB16B) to being a rocket ship in straight line while even having little less downforce than the Ferrari in 2022
- AM/RP/Force India went from being the fastest car in strzight line to being what it is today (a car supposed to win at Singapore)
- McLaren had a design from 2020/2021 which allowed them to master high speed track : Spa, Sochi, Monza but since 2022 the car is better on "karting track" (before the update)
I think sometimes it's also due to the driver really... Massa turned into prime Schumacher at Istanbul Park and it didnt mean the Ferrari were particularly good at this track...
I think for the example your are giving Hamilton was never particularly spectular around Monaco
NAPI10
NAPI10
Spoutnik wrote:
09 Jul 2023, 22:58
09 Jul 2023, 22:45
NAPI10 wrote:
09 Jul 2023, 22:38
Things like..
How difficult is it to change a 'Car characteristics' or it's impossible?
When 'Dan Fallows & team' took over reign from Green mid-last year; they had 2 tasks - Salvaging 22 season & build new car for 23.
Is there a possibility that they took a decision to change just 'Aero philosophy' on same last car characteristics due to Budget & time. That's the reason of not able to find additional gain with upgrades on this year car with old characteristics/weakness?
KimiRai
KimiRai
301
Both McLaren and Williams have a RedBull style undercut, while Aston and Alpine who have a much more aggressive outwash in that area have not improved as much. Probably not relevant at all though and I have no idea.
Tzk
Tzk
36
NAPI10 wrote:
10 Jul 2023, 00:21
It's not impossible, but each team has its own design philosophy and tools they developed to design the car. As long as the team sticks to these tools, you'll have a certain result in terms of car characteristics. That applies to tire analysis, windtunnel, CFD and all other simulation tools. Also a reason why personnel switching teams is a good thing. This way you get a new approach and other philosophies into your design department. You can change your approach, but it takes year to get it done.
Williams for example went for a low drag, low downforce approach in the past, which made them slow overall but impossible to overtake on the straights. At least unless you were way faster.
Same for the other teams. You design your suspension geometry in a certain way, you end up with a car which is (or isn't) gentle on the tires. Mercs for example seems to work them harder while RB is able to sometimes run a softer set just fine.
Tzk wrote:
10 Jul 2023, 06:50
NAPI10 wrote:
10 Jul 2023, 00:21
I don't think it works like that way. I think you have design failings (car weaknesses) that then drive your setup. Example Williams lack DF so the fastest way around the track is to set it up with as little wing as possible.
flexcon
flexcon
alonsofan wrote:
08 Jul 2023, 20:17
KimiRai wrote:
08 Jul 2023, 19:28
DGP123 wrote:
08 Jul 2023, 19:06
That would be me. Got slated for that opinion.
I said the honeymoon was over.
Fact is nobody can match Newey in this era of aerodynamics. Peter Prod went to McLaren and they have not done anything great. I think it's going to be the same with Fallows.
this is ageing like Milk so far.
KimiRai
KimiRai
301
Some interesting things from the car comparison thread.
Farnborough wrote:
10 Jul 2023, 09:12
Clearly there's performance difference which we can all observe, the team must be working on analysing why their design is in front or behind other's performance for variation in track attributes.
The AM downwash/waterslide arrangements do look more likely to generate drag figures at sub optimum in comparison to RB type to my view. Seem to have good separation of longitudinal airflow but at more drag cost.
The AM appears, through their flow vis image, to be pulling up airflow from outside flank of side pod and rolling that over into the trough on topside, as comparison to RB which seems intently focused on letting the top surface of the side pod bleed downward into the undercut channel as it progresses away from front inlet area.
The AM performance at season beginning I feel took them by surprise in it's ultimate performance, they all said they had good numbers but until they ran it against opposition they were right to treat with caution.
This in itself gives something of a pause in data and how the update route is defined, until they really knew exactly where they were positioned in regard to level against competitors, then throwing speculative design changes at it (to give continuity in update) would seem invalid to me. Establishing many aspect of this new chassis in real competition needs to be accomplished in driving true improvements from that new baseline. It takes time, which I believe we are seeing now as that understanding can't really be short circuited. It may be (in contrast to statements about updates previously) just the reality if now finding a refining direction that doesn't give inconclusive results, which could either be leading into more significant iteration or, given budget cap etc, leading to desirable core chassis changes list for 24 season in evolving their concept. They are effectively out of step with all the other team right from that mid season change in 22 in evolution of concept development time.
Alok91
Alonso: Aston Martin “cannot get stressed” about dip in F1 form
https://www.autosport.com/f1/news/alons ... /10494221/
Mansell89
Mansell89
There has been some very big progress from McLaren which probably exacerbates or exaggerates the AM “dip”, but I think it’s reasonable to say they haven’t made a big step forward from what was an excellent starting point.
I do however think they will go very nicely in Budapest as that looks on paper a track to suit better.
Jambier
Mansell89 wrote:
10 Jul 2023, 13:53
Compare to other they had very few upgrades and that is one worrying point.
But indeed Budapest will be crucial: we will see there what will be the rest of the season, is McLaren fast here, what can Aston do
On that track that check all the strength of Aston there is only one acceptable result: same as Canada
peewon
Its worrying the amount of talk coming out of AM is still about track suitability and pre season expectations. Yeah they made a huge leap from 7th to 2nd but they're already back down to 5th. The tyre deg advantage over Ferrari and Merc is seemingly gone. They're not good in quali. And their car suits much fewer tracks than the other teams. When Mclaren and Merc were down, they were very confident and clear about the direction in which they wanted to go. No one from AM has given any indication as to where they want to/should go.
Jambier
peewon wrote:
10 Jul 2023, 15:17
They don’t communicate that much but Krack said that they will have three races with upgrades
But now as Mercedes and RBR they are focusing on 2024
By the way I’m not sure that this is the right thing to do, it seems with those new regs that in season dev is as important as during the winter
I’m wondering if planning évolution until almost the last race is a good thing, it might be. And continuing the year after on that basis
basti313
basti313
Jambier wrote:
10 Jul 2023, 15:27
peewon wrote:
10 Jul 2023, 15:17
Well, I do not think it can or will be a good thing.
AM was very good at the beginning. Same as 2020 with the pink Mercedes. They basically sacrificed last year to have a good start into this year. So if they do not sacrifice the last part of this season as well it will be hard for them. They never had a goof in-season development, so relying on it will not end good in my point of view.
Furthermore the start of this season is certainly exaggerated by Merc and Ferrari having a very bad start. This is what I always said at the beginning until now: RedBull does not have a rocket ship, it is the competition that is missing.
Don`t russel the hamster!
