Vodafone McLaren MP4-27 Mercedes
Owen.C93
Owen.C93
177
Re: Vodafone McLaren MP4-27 Mercedes
SiLo wrote:
Owen.C93 wrote:
n smikle wrote:Different angles.
Luckily the front wing end plate and floor are parallel.
Thank you Owen :) the differences in angles, eleveation of the cars, part of the corner etc will have negligible effects on the relative angles of the wing and floor.
Also, Do Mclaren run a stiff front and soft rear? It seems that other teams run a soft front and stiff rear to keep their desired rake. Just my two cents there though :)
Another question, does the plane of the front wing have to be parallel to the floor?
The box that confines it's dimensions is so it may just be the end plate is designed within that. I'm not sure of any rule that deems it illegal if it isn't though.
Crucial_Xtreme
Crucial_Xtreme
404
New McLaren front nose analysis from Gary Anderson
Right click>view image
via AutoSport
Chuckjr
37
Is Macca going to run out if development space with its low chassis later in the year while the higher chassis cars continue to have options? It seems Gary in that article above seems to hint at that...? Are they in trouble come late Aug?
Watching F1 since 1986.
GrizzleBoy
GrizzleBoy
Possibly, but with many teams and analysts commenting on aero being less important than tyres, it may not have too much of an effect.
Tbh, I'd agree with them.
The "technically" least aero efficient car (at least at the front of the pack) won the first GP of the year and has been the most consistent qualifier of 2012.
240
Aero efficiency is still as important. It's a major part of the equation to get the tyres working.
A good car that can't get the tyres working would be even worse if the aero was not as developed.
Caterham and HRT are perfect examples of crappy cars gaining nothing of the tyre lotttery.
Chuckjr
37
This will be interesting to watch unfold as time goes on...
Shakeman
GrizzleBoy wrote:Possibly, but with many teams and analysts commenting on aero being less important than tyres, it may not have too much of an effect.
The team to consistently get on top of the tyres will win the titles. It's a lottery at the moment and the tyres appear to have such a narrow window of optimum performance that any change in track temp can be disastrous.
I expect to see gadgets appear that allow for making small changes to setup to work tyres better during races to keep them in near optimum performance for the race.
Get on top of the tyres then you can exploit all your aero brilliance. Given the whole field are struggling it's a good bet that it is far from easy! :)
Banki
Banki
I think it's impossible to make a higher chassis, isn't it?
myurr
myurr
Banki wrote:I think it's impossible to make a higher chassis, isn't it?
Not impossible but most probably impractical and infeasible for a mid-season update.
amouzouris
105
with a higher chassis they would also need to completely rework the front suspension
The chassis is fine. It's not that much lower compared to high chassis as the low nose when compared to high noses. It may only be a cm or two lower than others.
FrukostScones
163
high nose, normal small DRS-flap
Nando
Nando
Perhaps bringing both versions again?
I thought low nose was a given around here.
Owen.C93
Owen.C93
177
Nando wrote:Perhaps bringing both versions again?
Why?
Banki
Banki
Why?
Because of Button's problems in Spain
