Mercedes AMG F1 W04
elf341
elf341
Re: Mercedes AMG F1 W04
dans79 wrote:testing a passive drs system?
looks like the w03, but it has the w04 graphics on the cockpit, and rear wing.
Looks like W03. The wing mirrors, and rear wing endplate slots, and sidepods aren't right.
Huntresa
Huntresa
http://www.youtube.com/watch?v=X6URYQXKuCc
Where are you seeing a DDRS ? What i see is cooling such as Ferrari is running atm on its car, nothing else.
dans79
267
the secondary inlets on the hoop are like the w03, and has a completely separate runner, but like Someone else said the body work looks all wrong.
206 177 106 104 9 9 7
Huntresa
Huntresa
But its still not DDRS even if it was this years car, its cooling.
dans79
267
Huntresa wrote: But its still not DDRS even if it was this years car, its cooling.
either way, it's an interesting change to see.
MercedesAMG
MercedesAMG
heimana wrote:can anyone compare the height of the old and new nose? I can't see the difference
It's a new one for sure. It looks very different.
That is W02 from 2011
gray41
=D>
Lewis Hamilton #44
2016
Poles: *****
Wins: ***
dans79
267
http://img2.auto-motor-und-sport.de/Mer ... 700226.jpg
=D>
That's a big difference, I wonder what prompted the change.
I dont think it's anything specific, just an improvement in aero under the nose
theformula
Nope, it has always been there. Even if they were planning on testing a Passive drs system, they wouldn't be so naive as to show it on a video!
Hamilton's blessed with an ability to make a car do pretty much anything he wants - Mark Hughes
=D>
Nice spot!
The nose is a tiny bit higher by the looks of it, not much. Still, everything you can find that way is always an improvement. Same length, bit flatter. Pylons are flatter, wider and start at the nose top. Perhaps another tenth they find this way?
I find it interesting though Mercedes keeps placing their pylons right in the middle of the main plane, instead of the edge of it like most other teams do.
beelsebob
beelsebob
85
turbof1 wrote:The nose is a tiny bit higher by the looks of it, not much. Still, everything you can find that way is always an improvement. Same length, bit flatter. Pylons are flatter, wider and start at the nose top. Perhaps another tenth they find this way?
A tiny bit? Looks like 2-3 inches higher!
That's a pretty huge change.
RicerDude
27
That is the oil cooler inlet.
I think your eyes are playing a trick on you. They have gained, but just take above picture and draw an imaginary line from nosetip to the main plane. It's nowhere near 3inches. I think 1-2 inches.
Much more important is that they have gained some volume under the nosecone. It seems like they previously made the actual nose end in the nose tip, together with vanity panel, but this time the nose tip consists only out of the panel, giving the nose a bigger angle upwards.
