Because you can still improve the aerodynamics of the car, generate more downforce, improve drag, etc. The reality is that if you are rushing lots of small updates to the car then while you can make progress it is slower than working on one big update. If the press are right and there's a big update coming for Silverstone, then it's more likely that they're looking to take a big step forward with that update.hardingfv32 wrote:You guys are only talking about visible developments. We have no idea what the non-visible developments are.
What is the point more revisions when you still cannot manage the tires properly? What is the point when you do not have a good baseline on tire performance. There is every possibility that getting the tire setup right is worth more than the average benefit of a successful car revision. Why not concentrate on tire setup then?
Brian
We've seen it before when a team has a good base solution, the updates seem to come less frequently but they have a bigger impact when they do land. A perfect example is McLaren in 2009 when they were throwing everything at the car to drag it up the field and were making good progress, only to slip back again when all the other teams brought their updates for the European races, before they clawed their way back again. If I remember correctly then that year they even had to take a breather from the race by race updates for a couple races in order to bring a bigger package to the car.
With the RRA efficient development is more important than ever.
