Mercedes AMG F1 W04
Matt Somers
Matt Somers
179
Re: Mercedes AMG F1 W04
My conclusion is it's a strip of tape or paint too... That image although enlarged doesn't show the full extent of the imperfections near the edge if it were an aperture...
My 2p's on the subject...
http://somersf1.blogspot.co.uk/2013/07/ ... trick.html
lewishamilton90
lewishamilton90
-1
Abbiamo un paio di sviluppi che saranno montati sulla monoposto nelle prossime gare, quelle di rientro dalla sosta estiva“, ha esordito l’ex Ferrari. “I nuovi sviluppi dovrebbero garantirci uno slancio tale da poter affrontare al meglio la seconda parte del 2013. Dopo Spa e Monza, molti Gran Premi saranno lontani dalla nostra base e questo non permetterà di avere la stessa mole di sviluppi della prima parte di stagione. Sarà la stessa cosa anche per i nostri avversari.SIAMO CONSAPEVOLE CHE CIO CHE PORTEREMO SARANNO GRANDI INNOVAZIONI"http://www.blogf1.it/2013/08/01/brawn-a ... ent-249740
emmepi27
emmepi27
141
I think that the solution can be here:
Mercedes is the only with a air inlet on brake's fairing and i think it's just under the rim's groove. There should be a correlation between this inlet and groove... Wait for next race to solve the "mistery" :)
f1motta
f1motta
64
Here are some nice details about Mercedes front wing tyre temperature sensors - http://www.f1talks.pl/2013/08/01/jak-dz ... prace-opon
tony77g
tony77g
36
Matt Somers wrote:My conclusion is it's a strip of tape or paint too... That image although enlarged doesn't show the full extent of the imperfections near the edge if it were an aperture...
Totally agree with you Matt, and add this photo. It might help you figure out who still insists
watch the yellow line
Mika1
Mika1
And Brawn confirmed they will have even more updates coming for Spa and Monza, I can't wait to see them.
The boss follows me on twitter.
sucof
38
http://www.zaslike.com/
Except that it makes nearly no sense to create there a black strip and a rim, but makes huge sense to build a double walled wheel.
flynfrog
do you have any idea what it would take to cast a double walled wheel?
Multiplex
Multiplex
-1
It must be a slot and connecting to outside of the rim .
This should work as a heat barrier for the brakes , very neat work and difficult to make.
Fresh air blows trough this slot to the outside the rim.
GrandAxe
GrandAxe
My first post after lurking for years!
You are wrong about it being a strip. The reflections in the tyre tell it all, I've altered the image a bit with a couple of arrows to show the different directions the reflections point. Following these easily leads one to see the depression in the tyre. Further, the abrupt change of brightness at the end of the lip points strongly to an undercut or hollow area.
SectorOne
If it´s just a sticker, what purpose would that fill?
I´ve zoomed in on the big picture and it looks like a cavity to me.
dans79
267
flynfrog wrote:do you have any idea what it would take to cast a double walled wheel?
I see nothing in the rules that says it needs to be a single casting.
http://www.formula1.com/inside_f1/rules ... 2/fia.html
206 177 106 104 9 9 7
tony77g
tony77g
36
so maybe it is easier to understand
dans79
267
tony77g wrote:so maybe it is easier to understand
I disagree, if it was a surface, it would reflect light at least a little bit, even if it was rubber(unless it's a perfect black body).
Secondly, the two "bumps" on either side look like beads, and those are exactly what you would use to stiffen the edge of a thin cylinder.
sucof
38
When did it matter for a top F1 team to create something difficult? Especially if the teams biggest problem is rear tire degradation since 3 years now. If this is a solution for that, then it is a simple one I think.
I still do not get why would they paint it to black, what purpose would it serve, especially since we can see on the break duct that there is some opening right there where the supposed wheel rim openings are.
And especially since their biggest problem is tire management is this is a viable possibility.
