Caterham CT-05 Renault
Pierce89
Re: Caterham CT-05 Renault
Any ideas if any memorobilia sights sell one of those machined aluminum jigs to hold the front bulkhead?
JDC123
JDC123
30
Why is it that caterham are using to different version of their front wing. The one which kobayashi uses with the huge cascade and the smaller one that Ericsson uses. I remember reading there was only one of the updated front wings available when it was brought to melbourne, but why are they still using the older version now. Could it be financially they don't want to produce more of them on there reduced budget, as I seem to remember with HRT towards the later part of 2012 they appeared to be using parts from all sorts of different seasons.
flyboy2160
flyboy2160
84
All the guessing about the new nose and 2015 is in the Team thread. Just real car parts here.
matt21
86
First computer graphic of the new nose:
But looks still like the old one, the longer I look at it, to be honest.
Raleigh
Raleigh
29
It does look like the old nose...
Perhaps it is only a new vanity panel?
matt21
86
AFAIK the Caterham nose has a separate crash structure. So they will retain the inner structure in order to avoid a new crash test to be done.
mbchc
mbchc
So , they just smoothed out the nose tip a bit to crate a "new nose" :roll: Or we just wait for the real thing come out 8)
Mercedes AMG Petronas
AMG|||
lio007
323
adrianjordan
Well it looks less horrific....if that's something to aim for...
Favourite team: McLaren
Petroltorque
Petroltorque
That is actually a new engine cover and side pod with a smaller coke bottle. Must be part of the update.
I don't think it's a new nose. It's simply a new vanity panel. Caterham are locked into the low, narrow nose they had at launch unless they change the crash structure.
Caterham's new nose:
auto-motor-und-sport.de
timbo
timbo
113
I like it
F1T
Administrative bot
Caterham debuts new nose cone
Caterham debuts new nose cone - Development blog
It's a God's gift, Caterham's new nose cone on the CT05. While the visual appearance may not have been the top priority for the team in terms of aerodynamic development, the modified nose cone is a whole lot better looking that before. True, it could still be better, but such as the rules that strange looking noses are currently a good solution to keep airflow underneath the nose.
In any case, Caterham did not change much to the concept of its car, retaining the matte black cone that forms the front crash structure. Above that however is now a much more elegant structure, slightly rounded at the top and including a vanity panel to create a smooth, continuous upper surface towards the monocoque. With the team not modifying the front suspension, it's good to see how much higher the nose is around the upper wishbone, while at the bottom, at the connection point of the pull rod, the bodywork is more rounded.
pastaracing
pastaracing
Both cars run with new (better looking) nose, new side pods and new enginge cover.
Lotterers car have also a new floor.
Ericsson runs a complete new chassie for Spa, due to his last crash. This is a bit lighter but on the other hand they have to run with the old floor. That because the lack of time if I understand right.
They also have a new exhaust, new engine map and a different fuel.
All according to the Swedish commentator Eje Elgh who is well uppdated in the Caterham team.
pastaracing
pastaracing
[quote="SectorOne"]....
News from FP1. They changed Marcus brakes and adjust the brake bias in the wrong way, therefore the spin just before the timed lap. He had also problem with the fuel sensor and had lack of power.
