PhillipM wrote:beelsebob wrote:PhillipM wrote:I think he means something like a flat jacking plate with a ram underneath - the driver simply drives over it and the 'jack man' pushes a hydraulic cylinder down remotely?
How would the jacking plate magically be able to get down to 0mm above the ground for the car to drive onto?
Use a pillow....
I think PhilipM has the right idea.
The lateral center of the car, particularly the T-tray front, drags near the ground with little or no clearance. However, by rule the sidepods are at least 50 mm above the ground. This creates lateral space on both sides of the car between the low center section and the tire tracks. This space extends the full length of the car.
Commercial car lifts are available with profiles as low as 100 mm. Surely F1 can do 50 mm or less. It simply has to be split into two parts to clear the center section. The hydraulic lines connecting the two sides could go over the pit area like the other pnuematic and electrical lines already do. This two-sided lift would be activated by a remote hydraulic device exactly as PhilipM suggests.
Don't quibble the details. Is there a fundamental rule that would prevent this? Or do you think it's quicker, more reliable, and safer to have a front jackmen flailing around at the front during 2.9 second stops?
Edit: also credit to jason.parker.86
