McLaren MP4-26 Mercedes
Hangaku
Re: McLaren MP4-26 Mercedes
n smikle wrote: Hamilton says the 7th gear is too Long. The car is drag limited and not to mention it's top speed is lower.
Too much wing then lol. I want to see how this works out tomorrow.
Interesting risk from McLaren, but looking more and more likely for rain in Canada in this years race, so might be worth it.
What of any other additions to the car at this point in the season? Anybody got any images? Seriously lacking ...
Yer.
Pierce89
n smikle wrote:8) Again You didn't read the post but I will redraw the graph to please you. I will change the red line and black line.
Which one do you think is higher in F1, Form drag or Induced drag? Tell me so I can redraw the graph.
Induced drag is probably higher in F1, but th point is that on an F1 car all the drag incrases with the square of speed, bluff drag or induced, so we don't need a misleading graph seperating them and implying some sort of nonexistent difference in the way they build with speed.
SiLo
144
I think they will do OK in the race if it is dry, and if the race is wet, they should be sorted. I think they don't have the pace because they are leaning more towards a wet setup than a dry, or made a compromise, which obviously affected the car. Personally I would of gone for a dry setup and maximised qualifying, because both drivers are very adept in the wet.
Felipe Baby!
ianwit
ianwit
SiLo wrote:I think they will do OK in the race if it is dry, and if the race is wet, they should be sorted. I think they don't have the pace because they are leaning more towards a wet setup than a dry, or made a compromise, which obviously affected the car. Personally I would of gone for a dry setup and maximised qualifying, because both drivers are very adept in the wet.
Good call I have been practising the rain dance :mrgreen:
Became a McLaren fan in the late 70's when I ended up laminating their Kevlar nosecones.
Pierce89
Jensen is quoted as saying the rain setup rumor is untrue.
Owen.C93
Owen.C93
191
They haven't gone for a wet mechanical setup (increased ride height, softer suspension, etc) but their high downforce package is more suited to wet conditions.
I also just remembered that DRS should be banned in the wet, so that's a bit of a plus for them.
We can do the maths and derive which one is higher in F1. But my point is there is no aerodynamic disadvantage to reducing the form drag.
On the car itself, Mclaren has put the bulk of the radiator opening behind the front profile of the brake duct and the tyres so there is a reduction in form drag.
http://www.grandprix.com/jpeg/misc/mcla ... ch2-lg.jpg
I think at high speeds when the air is moving in a more direct way over(or through in this case) the length car the U-pod is going to be more effective.
Pierce89
OK I agree with this statement. I just said the graph was completely misleading and irrelevant for F1 purposes because of the way the form and induced drag are seperated, because with fixed non-changing geometry they both build with the square of speed making the graph misleading for F1 purposes
Ok the graph is wrong for F1 I knew from the beginning, that is why I said the F1 wings are not moveable to cut the down-force to what is needed as speed goes up.
Pierce89
n smikle wrote:Ok the graph is wrong for F1 I knew from the beginning, that is why I said the F1 wings are not moveable to cut the down-force to what is needed as speed goes up.
I just didn't want other people confused.
boydy19
boydy19
Any reason why LH and JB were under investigation for speeding under safety car. I seen from live timing that Vettel was doing 2.06 laps under safety car and people at the back were doing 2.02's? Lh and JB were doing 2.04's
Nobody actually seemed to know of the rule until today.
Car is good at warming up the tyres it seems. We were 1.5 seconds faster than RedBull in mixed conditions!
Poleman
n smikle wrote:Car is good at warming up the tyres it seems. We were 1.5 seconds faster than RedBull in mixed conditions!
Actually the car is preety strong regarding to race pace.DRS and the magic mapping for RB's advantage are gone come race day.Still needs improvement though.
Robbobnob
Robbobnob
regarding saftey car speeding, i think it was recorded in a sector where both of them went too quickly and their average speed was above the defined limit.
That McLaren was sure fast towards the end, just had such superior grip, wing setup? or perhaps the suspension characteristics?
