When Mark Webber - a fairly large lad - applies a 2000N force to the brake pedal he is not necessarily requesting the car to stop as much as when Felipe Massa applies a 2000N brake force to the brake pedal. The amount of force applied to the braking pedal only makes sense if you have extensive knowledge about the setup of the braking system on the car.beelsebob wrote:It kinda does actually... Okay it doesn't really tell you how much the car is slowing down, but it does tell you how much the driver is requesting it to slow down. In the same way as the throttle pedal position doesn't actually tell you how high the engine is revving – it tells you how much the driver is asking for go-faster.Caito wrote:He was talking of brake pressure and you quote newtons, which is force. What you get there is pedal force, which makes no sense to compare.
