aterren wrote:As was said, there is no free lunch
Either carry the Cyro liquid which is heavy
Or
Create / maintain it on board. In this case, the heat transfer from the source to cyro liquid must be then pimped out of the liquid into the atmosphere. In the very best case (ignoring losses) would be break even from an efficiency perspective.
Non-starter I would think.
Not sure if it is that heavy yet.. that is the thing.
Okay.. for example most of the refrigeration units that I have seen are heavy because of the materials. Cast iron compressor blocks.. Copper tubing... cast iron heat exchanges or thick wall stainless-,steel frames.. heavy bolts. large fans. These systems will be much lighter if they are done to formula 1 standards. It might be some sort of cascade refridgeration system. I know is a slim chance of being light but I just haven't looked into it yet so talking from a purely naive point of view for now.
