McLaren MCL36 Speculation Thread
jjn9128
785
Re: McLaren MCL36 Speculation Thread
timbo wrote:
08 Jan 2022, 20:45
So the driveshaft will be practically lying on the tunnel top?
Pretty close. The diff has to be between 250 and 260mm from the car floor, and between 60mm fore or aft of the rear axle line. The drive shaft can then be shrouded by the fairing for one of the suspension members. This member can be up to 150mm long (other susp arms may only be 100mm long) with the thickness ratio of 3.5:1 (so ~42mm thick).
Using the max height and moving the diff forward frees a bit more space above the tunnel, but adds an angle to the drive shaft.
#aerogandalf
Zynerji
112
jjn9128 wrote:
08 Jan 2022, 20:53
timbo wrote:
08 Jan 2022, 20:45
The angle lowers power transmission efficiency? By generating more heat? Can that effect be harnessed?
Stu
Zynerji wrote:
08 Jan 2022, 21:00
jjn9128 wrote:
08 Jan 2022, 20:53
timbo wrote:
08 Jan 2022, 20:45
It might have saved Leclerc’s gearbox in Monaco…
Zynerji
112
By offsetting the load path to the gearbox...
Interesting. 🤔
aleks_ader
90
Zynerji wrote:
08 Jan 2022, 21:00
jjn9128 wrote:
08 Jan 2022, 20:53
timbo wrote:
08 Jan 2022, 20:45
Harnessed? What u mean? Loss is cause of bearing friction and then formed into heat. That is lost for ever. Williams experiment with high shaft AoA in 2012ish combined with very low gearbox ended poorly. So yeah i guess if there would be a serious gain is hard to guess. Firstly i dont have rules measurement and proportions at hand to judge more precisely. But I would guess beam wing is still there to correct any negative effect from shaft and other elements. So yeah any play with extra geometry positions could be "engineered" around problem at hand.
Zynerji
112
aleks_ader wrote:
09 Jan 2022, 01:29
Zynerji wrote:
08 Jan 2022, 21:00
jjn9128 wrote:
08 Jan 2022, 20:53
High angle driveshafts with flexture u joints that lower at speed could be a way of getting heat back into the rim after the brake duct changes! 🤣
jjn9128 wrote:
08 Jan 2022, 17:27
Stu wrote:
08 Jan 2022, 16:05
Which makes going to pull rods awkward. I’ve thought of another drawback. The teams are all using pushrod offset to control low speed weight distribution; limited for this year, but there will still be a benefit to using pushrods.
Tunnel sizes may now put an end to pull rods at the rear too.
I don't think the tunnel height is a limiting factor (very much WIP)
https://db3pap006files.storage.live.com ... pmode=none
Merc-style inverted rear lower wishbones will be hard to implement then (or less useful, because they would pass very close to the tunnel?).. (but their extremely high pull rods will remain useful)
Stu
Blackout wrote:
09 Jan 2022, 16:56
jjn9128 wrote:
08 Jan 2022, 17:27
Stu wrote:
08 Jan 2022, 16:05
https://i.imgur.com/l9CkFmQ.jpg
Interaction between the wishbones and beam wing could result in interesting development opportunities.
_cerber1
301
By @ChrisPaulDesig1
Stu
Not entirely sure the front wing is legal?
(Fairly sure that jjn9128 will correct me if I’m wrong there!!)
Nice render though.
F1Krof
96
Wroom wroom
jjn9128
785
Stu wrote:
09 Jan 2022, 20:43
Nice render though.
Not much of the detail stuff on there is legal no. The raised nose, the S-duct is illegal, the wheel arches are wrong, the dive plane on the FWEP is too short, looks like there's a J-vane under the nose?!, the suspension arms have to join the upright above 40mm below the axle line so certainly the front suspension lower wishbones look too low, and it looks like the upper wishbone knuckles are outside the face of the drums on the front and rear wheels, slots ahead of the rear tyre are illegal, the beam wing looks wrong, and the rear impact structure is far too short... otherwise very nice.
#aerogandalf
CMSMJ1
CMSMJ1
jjn9128 wrote:
09 Jan 2022, 22:24
Stu wrote:
09 Jan 2022, 20:43
Nice render though.
Sure is purdy though eh :)
IMPERATOR REX ANGLORUM
Stu
CMSMJ1 wrote:
09 Jan 2022, 22:42
jjn9128 wrote:
09 Jan 2022, 22:24
Stu wrote:
09 Jan 2022, 20:43
Nice render though.
Oh yeah!!! 😂😂
djos
130
That is one very very sexy render!
However, the horizontal slots in the tunnel are A/ illegal (IIRC) and B/ would likely hurt the performance of the tunnels.
"In downforce we trust"
