McLaren MCL39
tok-tokkie
tok-tokkie
38
Re: McLaren MCL39
Vanja #66 wrote:
14 Feb 2025, 19:47
FDD wrote:
14 Feb 2025, 16:02
If I remember well that kind of geometry is anti anti-dive.
Different aero management/interaction that is for sure, AFAIK and based on many analyses made by You and some other guys on www.newsf1.it
As far as I know, over 100% anti dive leads to jacking, ie hopping under braking. It's more than bad
However, this would be a very different geometry, as you can see on this illustration, not really what McLaren is doing I think
https://livetodai.com/uploads/default/o ... 1e6d0.jpeg
These diagrams show that by lowering the rear arm of the upper wishbone they are REDUCING the ant-dive. Exactly the opposite of what the commentators are writing.
Andi76
Andi76
476
Re: McLaren MCL39
tok-tokkie wrote:
16 Feb 2025, 08:51
Vanja #66 wrote:
14 Feb 2025, 19:47
FDD wrote:
14 Feb 2025, 16:02
This is exactly what I and a few others have been trying to make clear to people for a long time. Just as the anti-dive value is ultimately influenced by other things... it's just complete nonsense what is being spread in the media that a low rear leg of the upper wishbone inevitably increases means "more" anti-dive. I also can't understand how people like Gary Anderson, who should actually know something like this, cheer such things on.
But anyway - what McLaren is actually doing here in my opinion, are two things - aerodynamic optimization and better driver feel/confidence. At the limit, especially in duels and under braking, Lando often didn't look good against Verstappen and Max usually came out on top. One reason for this could be a high anti-dive value, which impaired the feeling and feedback to the driver. One solution would be a lower anti-dive value with simultaneous optimization of the aerodynamics.
f1rules
f1rules
634
Re: McLaren MCL39
Remembering back when the anti dive was re introduced some years ago (again)
There was articles explaining exactly what you mention here. Its a fine line. If you overdo it, the drivers will loose feel for the car
BassVirolla
Re: McLaren MCL39
Andi76 wrote:
16 Feb 2025, 09:06
tok-tokkie wrote:
16 Feb 2025, 08:51
Vanja #66 wrote:
14 Feb 2025, 19:47
Some posters in this forum called me off for saying this same thing. :roll:
I'm happy to know that I'm not such a fool.
Even more, I think that in a front limited era, could be of some help increase the weight transfer under braking, and get the front wing near the ground in order to increase front downforce in corner entry.
Re: McLaren MCL39
Emag
Emag
137
Re: McLaren MCL39
As always, thank you for the detailed analysis. That hump is really interesting indeed, hadn’t noticed it before.
Could it be an underfloor redesign?
Looking forward to (potential) high quality images taken from the diffuser in testing to maybe deduce some changes.
Developer of F1InsightsHub
Re: McLaren MCL39
Emag wrote:
16 Feb 2025, 19:54
Almost certainly. It could be more pronounced now because the surrounding geometry sits lower, but this area where the vortex is developing has to be kept a bit higher...
Re: McLaren MCL39
trinidefender wrote:
17 Feb 2025, 19:23
Which other teams run double kick diffusers?
I think McLaren was the last of Top 5 to adopt this kind of geometry, back in Mexico last year
michl420
michl420
Re: McLaren MCL39
I think there is a cover over the floor by the inlet and the edge wing (or a show floor).
trinidefender
trinidefender
318
Re: McLaren MCL39
Vanja #66 wrote:
17 Feb 2025, 19:45
17 Feb 2025, 19:23
https://pbs.twimg.com/media/Gg9ejvBWYAA ... name=large
As far as I can see the double kick was there in the old design as well just that the initial kick was made larger.
Would you agree?
Re: McLaren MCL39
17 Feb 2025, 23:45
Would you agree?
On the outside we only see the local portion of the floor and Red Bull has previously used this area for a local pocket on the floor. Based on the actual photos of MCL38 post-miami underside, it was never a 2-kick solution, but the ramp has a certain upward curvature - it's not completely flat
ltitus8900
ltitus8900
Re: McLaren MCL39
This Mclaren is very Newey like to me. I might do a bad job of explaining what I mean but whatever. I like how the suspension aero is used together with the bodywork to help support the flows as it transitions to the beginning of the floor and how the bodywork of the chassis mirrors that of the aero ahead of it preserve a very powerful flow structure downstream. I also love how there is a relatively straight angle all the way back to the end of the sidepods. If they are able to get the flows to behave like they want it to, they should be able to work the floor quite nicely indeed.
I am happy that they kept the diffusor transition far back as well. They should have a beautifully balanced car if everything works as it should.
WardenOfTheNorth
Re: McLaren MCL39
17 Feb 2025, 23:45
Vanja #66 wrote:
17 Feb 2025, 19:45
17 Feb 2025, 19:23
Would you agree?
Forgive my ignorance, but what is the "double kick" diffuser?
"From success, you learn absolutely nothing. From failure and setbacks, conclusions can be drawn." - Niki Lauda
gcdugas
Re: McLaren MCL39
Everyone seems to be fixated on the aero effect of the top rear wishbone being so low but what is really in play is that the engineers have put a ton of anti-dive geometry. This will affect the tunnels far more than the aero effect of the lowered mounting point.
Innovation over refinement is the prefered path to performance. -- Get rid of the dopey regs in F1
