Red Bull RB21
venkyhere
43
Re: Red Bull RB21
Vanja #66 wrote:
01 Aug 2025, 13:57
New Front Wing on RB21: The spec introduced here is for high-load tracks and will probably be used in Zandvoort, Singapore, Austin and Mexico, maybe even Brazil if found useful enough. Highly cambered on the outside, Red Bull seem to try to keep smaller upwash along the nose where the air is affecting the floor inlet
It's very different load distribution across the span compared to previous high-load spec seen in Monaco, which features a moderate upwash mid-span
With that 'extremely turned-up' chord length 2/3rds of the way outwards, yes there is going to be more downforce, but what is the penalty in terms of airflow leaving the wing ? I wonder how much is the lateral flow going to increase by : which zone is going to get 'more wash' w.r.t the monaco(?) wing shown in the bottom pic ? inboard towards nose, or outboard towards wheel ?
Re: Red Bull RB21
venkyhere wrote:
01 Aug 2025, 15:10
Forgot to mention that, thanks. Increased outwash around front wheel should help mitigate losses in that area
Re: Red Bull RB21
Beware of T-Rex
venkyhere
43
Re: Red Bull RB21
From what I observed in FP3, this new front wing has been ditched (possibly as it was completely ruining balance) and the older Monaco wing has gone back to the car. The only change is the uppermost element now has a gurney added.
Re: Red Bull RB21
venkyhere wrote:
02 Aug 2025, 15:36
They might have switched to the old wing to rule out the update as the cause of the problems. Since the car didn't perform with either wing, then there's grounds to try it again at a different track.
Beware of T-Rex
Brahmal
Brahmal
77
Re: Red Bull RB21
Brahmal
Brahmal
77
Re: Red Bull RB21
chrisc90
Re: Red Bull RB21
Little ‘scoop’ on Rb21’s front wing directing air straight upwards.
Re: Red Bull RB21
Beware of T-Rex
venkyhere
43
Re: Red Bull RB21
Nice comparison pic. The spoon depth of mainplane is smaller, even though the camera angles are slightly different (which exaggerates the spoon difference), but what's satisfying to see is the difference in the shape of the flap holder edgepiece at either end - the new ones are more side-washy and have a gentler tip-vortex. Overall, just this camera shot comparison tells me that Redbull can fight for a podium with Ferrari and Mercedes, unlike the disaster of last year, with that high school craft project rear wing made with scissors.
ricardo91
ricardo91
Re: Red Bull RB21
Not sure if this has been mentioned, but apart from track characteristics and the mentioned upgrades Red Bull also fitted the cars with new front brake cooling ducts.
It might not be significant, but the change can be seen in this video here:
Farnborough
Farnborough
152
Re: Red Bull RB21
To place a perception/observation .... this front wing currently in use, appears to be moving to more dihedral (dihedral in aircraft lift application, but inverted for downforce here) that in greater perceived effect against their competitors.
Unsure if that's true, but as indicated my perception of that geometry in static layout ( not under stress) is moved to more dramatic effect with the outer tips obviously below the centre section under nose. The lowest wing plane also having its leading edge more lifted coming out from that centreline section.
IF so .... that would appear to favour less disturbed and more volume feed toward floor entry architecture and outwash via outboard "barge" strake arrangement.
I've made it clear this being perception of change over this season, this RB21 having noticeable more distance from ground under the immediate centre than the McL39 as reference.
Re: Red Bull RB21
There were differences between the Silverstone wing and the Monza-spec wing.
Beware of T-Rex
venkyhere
43
Re: Red Bull RB21
12 Sep 2025, 01:49
https://media.formula1.com/image/upload ... Monza.webp
So which was more 'loaded' - the Tsunoda monza wing, or the Silverstone wing ?
The pics don't show both in the same angle to compare the mainplane's spoon section.
Re: Red Bull RB21
venkyhere wrote:
12 Sep 2025, 05:33
12 Sep 2025, 01:49
I think the mainplane is the same or if it was modified, then it's very subtle adjustments. The flap tips are the biggest difference for Monza. Possibly just a CFD optimization as they did with the floor.
In Silverstone, there was a gurney flap added to the rear flap in addition to what appears to be draggier flap tips. Therefore I think Max's Silverstone wing has slightly more load/drag than what Tsunoda used in Monza. Gurney flap would add more load. No gf in Monza. I think the Monza flap tips are more efficient than the Silverstone flap tips.
Beware of T-Rex
